Sonicview Programming
Username: Nomo
Just bought an SV-1000 and need to program it for B$V 91. The programming guide which I found is a doc file and I can't access it b/c I don't have MS Word. Does anyone have an SV-1000 programming guide in PDF ? Thanks.
Username: Abj
Post Number: 364
http://totalfta.com/showthread.php?t=18804
Username: Mc_sunny
Post Number: 619
How too for sonicview
How to program SV1000 from scratch to get it up and going.
1. Ensure your using a null modem cable and it is
hooked up at both ends and your serial port is open in your computer Bios
2. Your unit is plugged into an outlet and turned off at the rear of the unit
Part B:
1. Download fresh copy of loader, factory bin and current running bin.
2. Place all files in the same folder as loader is located.
Part C:
1. With SV1000 turned off at the back, start loader program
2. Click STB -> Connect Config for Com 1
3. Click STB -> Download file (PC->STB) directing the downloader to the file you are wanting to load.
4. Window appears entitled Data Transfer -> Turn VS1000 on from the rear power button and do not touch it until transfer is complete and SV1000 reboots.
5. Turn off SV1000 at rear, disconnect null modem cable
6. Setup on TV and turn on -> configure, scan satellites and watch TV once autoroll kicks in
7. Autoroll can take up to ten minutes the first time. Until the keys roll you will have a black screen and red message No Service or Scrambled appearing. Do not panic, have faith. if after ten minutes no video, hard boot from rear once and video should come in.
When loading load the factory bin, current bin, satinfo, channel lists in that order when required.
how to change keys
1. menu>entertainment >code 7890
you will not see code until those numbers are pressed
2.press ok
3. scroll to nagravision then down one then <> to provider of choice
4. scroll down to numbers 10/11 first set 20/21 second set
5. enter keys save and exit
Soinicview how to get 7 day EPG
Go into Menu>>>System Setting>>>User Option>>>turn Stand-by-mode EPG "ON", then turn off your receiver OFF by using the remote control for 4min and turn it back ON. Now you should have fully 7days EPG, this is one time thing only until you switch the receiver OFF completely by using the rear power switch
Cloning Sonicview
Box-to-Box transfer:
Have the Master box power "ON", and slave box power "OFF" completely
Connect Master and Slave box with Null cable
User remote control unit pointing at the Master and press YELLOW button and #4 (#1=Main software, #2=Channel list, #3 Bootloader, #4= ALL)
Now power up the Slave box by using the rear power switch and you should see it start transferring
Wait until it finishes and reboots
Username: Nomo
Thanks MC Sunny and justice, much appreciated.
