Digiwave question
Username: Davinci0862
Winnipeg, MB Canada
Hi! I am a new "poster" here, but have been reading for a while. I am hoping someone will take pity on me and throw some advice my way. I have a DG 7000 and other than just throwing it out, I thought I would try to get T5 or something else. My problem is I just cannot seem to lock on to T5, I keep getting the BEV sattelite, (must be 91) Should I just stick with BEV? Is there a working bin for Digiwave? I know there is not for Globecast on T5 but is there anything that I can just pull in with my receiver? I have both linear and circular LNB's so I can use either, and a 33 inch dish.
Username: Satscanner
NDS Laboratory
U can go to Lyngsat com* , there is ur sat lists u can chose from to get any tru fta. I"m not sure shure about ur bins tho" check dsstester com* for files,no need to register. hope it helps. remove the star for the website
