Jumbled up wireing previous owner need help
Username: Swampthang
i need a wireing diagram or the color code for a 1989 f150 the previous owner cut up the wireing harness for the radio so i need to know what wire gose where
thanks
jason
Username: Leew
XXXX!!WWWW, Yokosuka, ... YAKUDZA JAP...
Post Number: 1145
Well this the schema for your car(actually for F150 and Bronco), but
I am not sure about the (+) and (-) on a speakers!
application/x-zip-compressedUpload
1989 ford f150.zip (16.3 k)
thanks this will work fine
jason
Username: Leew
Post Number: 1146
thank you so much got it all working fine
Jason
