Need help
Username: Oakland_az
Oakland, Ca
Post Number: 26
ok guys i have 350-450 to work with. I want a pair of good 5 1/4 coaxial speaker(1 pair). 4 channel amp.and a 10" sub going for sq mostly.
and if you can post websites where i can get them cheap that will be cool.
THANKS!
--i know this is the amp section but the other forum pages are not working.
Oakland, Ca
Post Number: 27
and i want to buy for online stores, not ebay but if i dont have a choice i might use it.
and i dont have a account.
so i have to use "Buy It Now" thing.
THANKS
Oakland, Ca
Post Number: 29
please help, anyone??!?!
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1308
diamond audio D9 series are good components. CA&E reviewed some pioneer components recently and they gave them a good rating. but you want to spend a total of 450 on components, amp, and sub? you will deffinately want to run all of the speakers on the same amp to save you money. let me see what i can find
Oakland, Ca
Post Number: 31
hey i really don't want componets i rather stay coaxial because it's going in a limo, also because componets are a little expensive.
and i might CTMIKE PGX400.1 for 150. i was thinking the Boston G2 10" good or no?
Thanks for posting!! and i need a good 4 channel amp to run the mids/highs.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1309
sub:
http://cgi.ebay.com/NEW-INFINITY-KAPPA-PERFECT-10-1-10-SUBWOOFER-1400-WATT_W0QQi temZ110056209594QQihZ001QQcategoryZ3291QQrdZ1QQcmdZViewItem
amp:
http://cgi.ebay.com/KICKER-ZX-ZX650-4-4-CHANNEL-650-WATT-AMPLIFIER-NEW-06_W0QQit emZ250049786861QQihZ015QQcategoryZ4950QQrdZ1QQcmdZViewItem
Components:
http://cgi.ebay.com/INFINITY-KAPPA-50-5CS-5-25-COMPONENT-SET-NEW-w-tweeter_W0QQi temZ250049786859QQihZ015QQcategoryZ32818QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I don't recommend buying from indoaudio though, but this should give you a good starting point and should sound really good. you will still need stuff to install amp. (rca's, wires, etc.)
Oakland, Ca
Post Number: 32
hey lucas the links didnt work.
Oakland, Ca
Post Number: 33
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10130
PG Xenon 400.1
AA assasian
Crystal Csc comps
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1315
the setup that chauncey gave you is better, but he left out the amp for the components. here are the ebay item numbers:
110056209594
250049786861
250049786859
