C oolsat autoroll
Username: Kille
Post Number: 7
I have the 135 bin file loaded for my c oolsat 5000, and the autoroll is set to on, but I still get ecmed.....any suggestions????? thx
Username: Hanz
Post Number: 87
Try switching the receiver off from the back for a couple of minutes. If that doesn't work, bring your dish inside the house, it might be too windy out there, causing signal disturbance.
Username: Hardrockstriker
Post Number: 595
Tom, try doing a factory reset on your recevier. With the power off hold the channel-up button while pressing the power-on button. You will get a menu. Select "NVram clear". Make sure to write down all of your receiver settings before you do the reset, as you will loose them.
Username: Meyou
Post Number: 43
Try loading the new 136 bin. Auto roll seems to work faster, still not perfect though.
