INDIAN channels
Username: Abpatel49508
ST JOSEPH, MICHIGAN USA
Post Number: 8
I havePANSAT 2700E. I can get only 3 channels B4U,ZEE TV AND ZEE CINEMA.I scan 3 times but it doesn't scan rest of the channels.Also I did factiry reset and auto update on and off both ways.Does anybody have answer for me.Thanks in advance.
Username: Crazy_greek
Post Number: 155
Hey Patel
Are you on bird Echo 9 @121.oW ?
OK now check you Longitude and Latitude.
On Antenna Setup make sure that DiSEqC is set to off. Now do a (TP) blind scan
Username: Dishall
Post Number: 13
i have pansat 2700E and have same problem missing few south asian channels ihave echo 3
@ 61.5, any answer for that,
