Need radio harness cable colors 2001 Altima GXE (non-bose)
Username: Beachguy420
LA, CA USA
Hey Guys and Gals,
I'm a noob so please be patient
anyways... I was installing a new headunit when my factory wiring harness was damaged (dont drink before you work on an adapter that is stuck)
and basically i need the cable color to pinout number for the factory female side.
I have the FSM but im not sure that its correct because
a) its correct some cables are marked as color "L" but those cables are actually blue. i have the rear speakers hooked up correctly because that side was not damaged.
b) i got it off the internet
c) i might be a dumb a** and reading it wrong.
so if anyone has this car, do me a favor and take a picture of the top and bottom sides of this factory side of the radio wiring harness for me.
thanks,
Beach Guy
