How to refresh EPG
Username: Mississauga
Post Number: 22
The only way I can get the current EPG is by switching off receiver and then back on. It then asks me if I want to load the EPG or not.
Is there a better way to refresh and load the current EPG
Thanks
Username: Mc_sunny
Post Number: 590
There is no better way then that at this moment
Username: Danoh
Post Number: 23
some models have a recieve guide function in the system setting
Username: Ke5aqn
Shawnee, OK USA
Post Number: 61
This EPG issue has been bugging us all. Also in your post I do not read what receiver you are using and that makes it hard to help you. I have the pansat 3500 and have only a 2 hour guide that on DN will keep up SOMETIMES but, never on BEV I have to power off and back on then wait 1-5 min for a EPG. I feel it is still well worth it compared to the what $500 a month on programing I am "testing". If you add up all the pay per view we watch, all the movie channels its great.
so the short answer is we all have that issue as well We hope the great programmers someday soon will fix this issue. Just watch for a new .bin file. Meanwhile we will reboot to get current guide.
Username: Albino_midget
Post Number: 309
with my 3500 w/367bin & allow epg to d/l i get 2days epg
with cw600s w/126 i get epg to populate by going to channel 119 (biograghy) and turning off/on via remote & then do the same for channel 200 (cnn)--works for me goes from 2hr to 12 hr epg
may work on other sats using these channels
91:
Global TV - Toronto
CTV - Toronto
Fox News Channel
The Learning Channel East
Discovery Kids
A&E
Star TV
Space
82:
The Racing Network Canada
119:
Cnn
CNN Headline News
HBO West
Showtime Too East
110:
The Biography Channel
VH1 Classic US
Military Channel
HBO Latino East
Showtime Showcase East
The Movie Channel West
The Movie Channel Xtra West
121:
Polsat 2
TVN 24
Kino Polska
RTV International USA
Aljazeera Channel
MBC USA
148:
Polsat 2
TVN 24
RTP Internacional América
Aljazeera Channel
Geo TV International
105:
WRIC-TV
WTVR-TV
WWBT-TV
WRLH-TV
WCVE-TV
WCVW-TV
61.5
Polsat 2
TVN 24
Username: Hardrockstriker
Post Number: 598
It sounds like you have a Pansat, Missisauga. There are a couple of things to note about EPGs.
The memory capacity (RAM) or your receiver determines how much EPG (1 hour, 2 hour, 8 hours, etc) your receiver can store. For example, a Pansat 2500 may only get 1 or 2 hours, while a Pansat 3500 will get a lot more.
EPGs load, of course, from the satellite, so the signal has to be good. Sometimes you will have to put your receiver on a channel with a strong signal in order to populate your EPG quickly.
Some bins are coded better than other. I find C00lsat has a better EPG than does Pansat. It's just the way the bin was written.
Lastly, EPGs rely on having your timezone and correct time set on your receiver.
Hope that helps you understand.
