Running a blind scan on Nimiq 2 82W misses some channels. I tried to run a manual scan on a specific TP-16 but the signal strength is not there. Quality level reads about 10%. Overall signal strength for the staellite is above 80%. Is this a common problem? Do I have to adjust the dish a bit to get a particular TP? If I do , will I be missing some other TPs? Expert opinions and suggestions please. Using CS 5K. Thanks
Bev most-likely moved the channel from that particular TP to another satellite. You should make sure your AutoTP feature is turned on and that you are also hooked into 91 sat.
Check lyngsat to find out what channels are where.
