110/119
Username: Duffydog
Post Number: 13
I finally got my bracket up with 110 and 119 but my 110 is coming it at a signal strengh of 90% and 119 is in the 40's.
If I move it won't I lose strengh on 110 or is it normal to have about 65% on each.
Thanks
Username: Johnner
Miami, Florida
Post Number: 996
Luke Warmwater
Just try and try until you get it is the only way.
Username: Tapeman
Post Number: 40
Actually if you got 90% that is great
Adjust the skew to 30 to 40 degrees
Because what is happening is 2 SATs are kind of close if you don't skew you will get one SAT and lose the other.
This will vary from one bracket to another
Username: Bphil3
I hope i'm posting in the right place. I have a pansat 3000; antenna setup recognizes echostar 7 satellite 110; i get all the ppv's; but won't recognize satellite 119; signal strength is at 90 for both; what can I do?
Username: Sunny890
HI Guys
Is there a way to get BELL or DIRECT tv programming on DN recievers if i am using "VIEWSAT". pLS HELP ME !!!!!
Username: Sunny890
GUYS
If I am using 4 in 1 DISEqC switch then where should my cables for 110/119 and 148 go ie into which LNBs---is it LNB1, 2, 3 OR 4
Username: Bones714
SO.California
Post Number: 177
Sunny, it's possible to get both providers. I got only 110 & 119, but have been reading lots on Bev also. I got my diseqc setup, 119 on port 1 and 110 on port 2, your 148 should be port 3 and so on for additional satellites.
