Bronze Member Username: Mike20Post Number: 31 Registered: Oct-06 | Alpine x-10, with an alpine mrd-m1005 monoblock. These subs can be wired all different ways. Im going to hook up only one to that amp. What way should i wire it? You can move these clips and wire it differently. So which is it, Series, Parallel, or what? The sub says on it its a 4Ohm+4Ohm |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3281 Registered: Sep-04 | if its dual 4 ohm then you should wire it parallel for a 2 ohm load |
Bronze Member Username: Mike20Post Number: 32 Registered: Oct-06 | Ok, so i should move the clip so its running parallel, so do you know if their should be 2 sets of wire coming from the sub? 1 positive and negative for each voicecoil? Or running parallel eliminates seperating the voice coils, and wiring parallel its like wiring both voice coils with one set of wires.. Did i confuse you? |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3284 Registered: Sep-04 | you've already confused yoruself lol. here... http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2 |
Bronze Member Username: Mike20Post Number: 34 Registered: Oct-06 | Ive actually tried to copy that similar wiring guide and i did... Even though the alpine sub is set up a little different i pretty much did what it shows on that link and it still seemed to not sound right.. Do u think i should wire it like it shows, But also pull out the clips on the sub?? I left them in when i wired it using this diagram. Thanks for the help |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3293 Registered: Sep-04 | i dont know what "clips" are. |
Gold Member Username: Van_manBoston South, MA Post Number: 1214 Registered: Mar-06 | Dont you have the manual? Did you check the site? dont be so lazy. Do some research. Look at the 2 ohm wiring. http://www.alpine-usa.com/images/products/documents/OM_SWX-1042D.pdf |
Bronze Member Username: Mike20Post Number: 35 Registered: Oct-06 | Chill out im downloadin the manual now.. Dont get hostile. I dont know either. On the subs theres these 2 clips that u can pull out to wire them different ways. Thats why i was wandering, cause u can move the clips to Series, Parallel, or i can leave them where their at... |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3300 Registered: Sep-04 | theres no other way to wire them than series or parallel lol |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1047 Registered: Jan-06 | sure there is...use 2 amps and wire them seperately....but not something I would do. |
