Loud 15"s
Username: Kickerman
Post Number: 43
i need two loud 15"s i dont know much about sq sql and all that i just want to be heard outside the car from about a quarter mile away. From what i read the L7's are pretty loud but no one wants them. someone please help
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9962
just but the subs on the hood of ur car...that should be loud enough
Username: Oglejust
15in re sx, Il Us
Post Number: 361
budget?
Username: Kickerman
Post Number: 45
between 600-750
Username: Oglejust
15in re sx, Il Us
Post Number: 362
2 15in fi q's 558 shipped great subs. www.ficaraudio.com
Username: 420alldaylong
Post Number: 738
Justin
What amp are you useing on your RE SX 15" and what ohm is your sub.
Post Number: 739
My bad I see you got a Elemental Design Nine.1
Username: Livin_loud
Ny
Post Number: 411
I got 2 L7 15's for sale :-) and they do get loud lol
Username: Volfenhagking1600
Atlanta, Georgia USA
Post Number: 153
memphis mojo
Username: B101
Post Number: 3718
mojo 15, tsx 15, ssx 15, l7 15....
damn its alot of 15s that get loud, how loud is loud ??? :-)
Username: Kickerman
Post Number: 46
ok out of all the ones mentioned above which one would get the loudest. that includes it being put in the appropriate box and having the adequate charging system
Username: Kickerman
Post Number: 48
bump
Username: Drivingreckless
\red {TREO}, \orange {USA} \3 {soon to ...
Post Number: 2218
i have a treo SSX 15" for 450 shipped to your door
Username: Ctmike
Ct.
Post Number: 2304
they all get loud. depends on your budget for amps to, and if you have an upgraded charging system. with your budget for subs i'd go with the q's.
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 873
To get loud, depending how loud, cost a lot of money. I spent a little too much =\. Do you have room for 15's?
Post Number: 2219
PIX
http://upload4.postimage.org/986684/photo_hosting.html
http://upload4.postimage.org/986686/photo_hosting.html
http://upload4.postimage.org/986740/photo_hosting.html
Username: Stnorris
Davenport, IA US
Post Number: 1565
haha why are u selling the ssx now?
Username: B101
Post Number: 3736
lol, his sig says "soon to be dd" :-)
"ok out of all the ones mentioned above which one would get the loudest. that includes it being put in the appropriate box and having the adequate charging system"
the question is how much power can u offer... what amps?
Fi AudioBTL
Post Number: 7014
hey driving no space between the "\red" and the "{TREO}". same goes for others. if you don't put a space between it then it should look like this. also 2 is the biggest font you can use.
TREO, USA
soon to be DD
Username: Kickerman
Post Number: 49
i have two kicker kx 1200.1's
TREO, USA
Post Number: 2223
then my sub would be perfect for it
ull be givin it bout 3k
wanna buy it?
Username: Rvlacos
DD 3512 United States
Post Number: 378
both amps on one 9515 that should be loud enough
