8" Diamond Audio Sub + Amp question
Username: Adelphia83
Colorado Springs, CO USA
Post Number: 70
I have two Diamond Audio M3081.8 8" DVC woofers in a sealed box with 0.5cf each. The woofers are 4 ohm DVC.
The amp I will be using to power these is an Audiobahn A8002T (400x2 @ 2ohm stereo, 800x1 mono @ 4ohm).
I understand these woofers are rated at 125w RMS each. I'm concerned about overpowering these with the Audiobahn amp and the woofers wired to 2-ohm stereo. Would I be better off wiring for 8-ohm stereo? Which is the best configuration?
Any help would be greatly appreciated.
Username: Logan__tille
AudioqueUSA
Post Number: 2383
I wouldnt over power thoes subs, especially by that much.
Post Number: 71
So wiring these up in 8-ohm stereo would be a better idea? What kind of power would I be running @ 8 ohm stereo?
AudioqueUSA
Post Number: 2386
yea, i would wire them 8ohm, they would prolly be seeing 200-250rms...im guessing.
Username: 54danny54
Betsy layne, Kentucky..GO... \blink, red,...
Post Number: 2855
75 watts over each isnt that bad. diamonds are actually decently durable
Username: Riskyb
Post Number: 375
Diamonds can take a pretty good beating. That much power at 8 ohms would give you some excellent mid ranges out of those.
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 949
8's?? damn, why not go with at least 10's??
Post Number: 72
The enclosure needs to fit behind the rear seat in a crew cab truck. No room for 10" woofers, the depth of the woofer can only be just over 4". Plus the enclosure size is only 0.5cf per side.
I'm not looking for anything outrageous (if I was I wouldn't have bought a truck), but anything over stock would definately be a welcome addition.
Username: Tjmutlow
Post Number: 3179
wire them stereo mode at 2 ohms.
