Can i do this???
Username: Blainew
Diamonds in the back.
Post Number: 1802
i have 0 guage running to the trunk.... can i put the 0 guage into a distro block that has 2 4 guage outs and run 4 guage to my amp.....
and then... run 4 guage ground from my amp to another distro block (0 guage to 2 4 guage) and then ground the 0 guage.....
0 guage to 4 gauge 12 volt
4 gauge to 0 gauge ground
can i do that?
Username: Rovin
Trinidad & T...
Post Number: 9693
y not simply buy a biger distro block that has 3 or 4 outputs from a 0g wire .......
Username: Tdawg30
Ohio USA
Post Number: 506
yup it wont hurt anything
Username: Oglejust
15in re sx, Il Us
Post Number: 360
sure but running small to big prolly isnt gonna help.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1264
just try to keep the 4 ga wire as short as possible and you will be fine.
Username: Blainew
Post Number: 1804
but that why ill make em as short as possible....
