Toshiba TheaterView TZ-55V61 sound problems
Username: Twizzy
I recently bought a 55" Toshiba rear projection theaterview TV used. Everything works fine, picture is good. The only problem I've noticed is the audio levels. The low-end and bass is overpowering the high-end. It ends up that most vocals get washed out. However, in the menu the levels are all set equal. Any idea on how to fix this?
