Box help please...
Username: Highstone
Post Number: 299
ok can someone gimme a diagram for the box of this sub.. 10w3v2
the specs can be found in the link. thanks
what kind will be good for this sub. ported or sealed? if ported i would like it to be 33hz
http://mobile.jlaudio.com/products_subs.php?series_id=11
thanks
Username: J_baby15
Kentucky
Post Number: 767
JL has a box diagram for that sub on their site.
Username: Highstone
Post Number: 300
do u know approximately how much money will i need to make the box?
Username: Highstone
Post Number: 301
how much wood would i need.. what kind of wood..
thanks
Username: Frkkevin
Post Number: 1619
1 4x8 sheet of MDF.. aprox $22 give of take some taxes.
Username: Highstone
Post Number: 302
and where would i be able to get MDF ? would home
depot have it?
Username: Bump05
Hesperia, CA USA
Post Number: 228
yea get 3/4"mdf home depot will have it
Username: Highstone
Post Number: 303
ok.. i don't have any cutting devices.. will home depot and/or lowes cut it for me? if so .. is it free or do they charge.? if they charge.. do u know how much?
thanks
Username: Bump05
Hesperia, CA USA
Post Number: 229
They'll cut it for you, and its free of charge but i wouldnt recommend that cause they always seems to make the cuts un even... cut it and your own pace or find a friend who has some tools cause when u cut most your peices that are for instance 18.5 would be the heith for like 5 peices they all need to be cut at the same time for pefect only makes it nice and makes it easier on you,just take you time
Username: Frkkevin
Post Number: 1623
lowes will cut it for free.. never had them cut wood so who knows how straight the cuts would be.. depends on who was cutting it i suppose. you can pick up a skillsaw for cheap and get two clamps and a straight edge and cut it yourself
Username: Fi_car_audio
Hades, NV
Post Number: 40
both have panel saws and the cuts are straight as can be... they are not "precision" cuts though so dont expect every panel to be the same down to a 1/64th of an inch... but thats what a little extra liquid nails is for and some sanding after the fact ;)
If you have an extra $50 to kill... I second the purchasing of some tools to do it yourself. You can pick up a cheapy jigsaw for $20 at Walmart (although cutting long straight sections with a jigsaw does suck, using clamps and a straight edge will make it MUCH easier... just as cutting cirlces for the subs will suck with the skilsaw...lol)
Thanks...
Scott
