Silver Member Username: Oglejust15in re sx, Il Us Post Number: 343 Registered: Aug-06 | ok i got some mdf today so now im working on plans for the box. ive got this so far. my only concern is port area. what does port area do cuz i saw on the port calculator thing that i need 80in2 minimum. will this work? http://www.subwoofertools.com/forum/ported-box.asp?Ew=38&Eh=16&Dia=9&Xmax=22&Vd= .18&NumW=1&Vb=5&Fb=35&Qts=&Vas=&Fs=&CE=0 |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 1562 Registered: Nov-05 | that would be great.. but I'd personally drop down to 4 cubic foot.. i would have sold you a box made for my SX for $50 + shipping but it looks late for that now .. |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1557 Registered: Apr-06 | 37.7 wide, 17 deep, 16 tall. 10 x 4 port(interchangeable, 18"s long that will ne 3.8 cuft net @ 34hz. ...thanks MW> |
Silver Member Username: Oglejust15in re sx, Il Us Post Number: 345 Registered: Aug-06 | what would be the difference in sound between a 5 cube box and a 4 cube box? |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 1563 Registered: Nov-05 | the chance to bottom out in a 5 cube is greater.. less control over itself.. thast why they rec for that sub was 3.5-4.0 foot but unless you don't throw more than the RMS on that sub 5 cubes would be fine.. i just like to stay with company specs |
Silver Member Username: Oglejust15in re sx, Il Us Post Number: 346 Registered: Aug-06 | k ill go wit 4 cubes but just cuz i like u kevin lol thanks |
Silver Member Username: Oglejust15in re sx, Il Us Post Number: 347 Registered: Aug-06 | hey... another question does a flare port make it any louder than a slot port? cuz i was gonna go with either a 5in slot port or 4 6in flares |
Silver Member Username: 420alldaylongPost Number: 724 Registered: Sep-06 | Justin What amp are you going to be useing? |
Silver Member Username: Oglejust15in re sx, Il Us Post Number: 348 Registered: Aug-06 | um my friends ed nine 1 |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 1567 Registered: Nov-05 | depends on the install but in some cases it does.. from what I've seen on polos experience he used both slots and aeros and said the aeros made a big difference in spl.. but if you went that route I'd just use 4 4" aeros |
Silver Member Username: Terry6405Sullivan, IN US Post Number: 947 Registered: Sep-05 | i would have sold you my areo box for like 70 bucks |
