Zee, Z Cine & B4U
Username: Kashif
Post Number: 22
How to get these channels on dish network? Anybody watching them?.Thnx
Username: Ustaad_hc
Post Number: 123
echo3 61.5w
all runing fine.
Username: Dude123
Post Number: 520
David
All channels should be working with the keys below,if for some reason they are not working then switch you box from the back switch and turn it back on after a while that should solve your problem, if not then do a blind scan
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov7 6pm EST)
Key0: 5F 9E 52 EE 1A A7 22 53 2C 08 3A 08 3A BA C1 57 (Active)
Key1: CD A2 C8 49 08 BA E5 07 D0 1C 28 5C FD BA 3E 8E
Bev Provider 0901: Last Updated (Nov5 7pm EST)
key0: F6 3D F2 E4 CE 6E 22 44 6B 87 79 6F 66 7C 3F 8E
Key1: 3A 57 A1 68 55 D9 18 21 88 89 87 D5 16 FA 0A 55 (Active)
Username: Senators
Post Number: 29
u can also get these at 148 i think that echo 1.2
Username: Fidarahman
Post Number: 80
These channels run fine sometimes but disappear for a while too.All other channels on 61.5 keep running while these 3 channels give up...any reason why???
Username: Pungi
Post Number: 10
because those three channels moved to new TP..27(12603). You can get back them by TP Scan -27 or doing blind scan
Post Number: 81
I tried to blind scan and tp scan for 27, 26,25 but the channels are not there, also 2TP 27 is not 12603 as said
Username: Mc_sunny
Post Number: 569
Somtime u won't catch any signal on that tp.. so to make it work...turn off ur reciever from the back and turn it back on after 2 min...Then try doing Tp Scan # 27...if u still dont get anything do the samething over again..Good luck
Username: Themangod
Post Number: 45
yes channels moved to tp 27 just make sure you have signal and Q of atleast 70 scan make sure all up-todate files.
Username: Ars88
has anyone here heard of channel mtv desi its an all indian channel that shows music 24/7
i think its called mtvn or something like that.
its not b4u music incase thats what u thinking i seen it once at a restaurant but cant find it on dish maybe its not on dishnet?
any info?
Username: Pannu16
Post Number: 330
U can get ZEE TV AND ALL Channels u lost by moving ur dish very very slightly. B'coz TP27 is very sensitive to alignment of ur dishes, i lost them too went out asnd moved it just2 cm , my signal quality increased and i did a scan and damn they were workin for me.
Arslan i love desi MTV, i think its on Direct TV!!
Username: Ars88
damn, no way fta can pick up that channel?
Username: Pannu16
Post Number: 333
no i dont think so but that channel is best!! i love it, i am glued to it wen i go back home!!
Username: Nydas
Post Number: 859
Arslan: Indo-Pakistani Music Channels
674 INDMU TP 12442(H) on ECHO 3 (61.5w)
663 MUSIK TP 12659(v) on ECHO 3 (61.5w)
The 663 MUSIK, in particualar , gives some very interesting music
Username: Ars88
Post Number: 7
ya nalin i got those channels but i want mtv desi lol they have the good indian music indmu and music is pakistani music its great but i want the indian music too!
b4u music is good but there are so many trailers and ads and all that so very little music but nontheless they do have music....
also nalin or anyone, i need some help with my american dish..when i blindscan echo 8.10 i get a message that says 0 transponders found and if i do get anything, it scans echo 7 channels when i do a blindscan...what can be the problem? it used to work perfectly fine before i started a thread but no1 seemed to answer me so please any1 gimme a hand here
thanks in advance
Username: Pannu16
Post Number: 334
arslan wat wud nalin know bout MTV india b'coz he is one low cals trash of india!! he wud not have even heard bout mtv india!! LOL< LMAO!!
Username: Xtrawest
Post Number: 38
Guyes.. go to mtvdesi.com, scroll the page to the buttom and click on GET MTV DESI, more we voted there, more the chance they will start MTV Desi with DishNetwork.. TTTTRY
Username: Ars88
Post Number: 10
lol good to give it a try if enuf ppl vote def. will make a difference! everyone vote!
