Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 737 Registered: Nov-04 | We have 1.3cubes sealed per 2 woofers. 2.6 total between 2 chambers. We are down to these choices. 4 RE SR10", 4 eD 11kv2 or 4 10" RL-i. Looking for the most spl. we are doing this cause he wants to retain his back seat in the ext cab truck. All setups will have 1 eD NINe.1 amp for power. |
Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 738 Registered: Nov-04 | http://www.supercrewsound.com/shop/detail/11/192.htm thats the box if you wanna see it and maybe suggest some other subs that will work. When i get the box im gonna put another bead of glue on the corners and coat the inside with resin for some more strentgh since it uses 5/8 mdf. |
Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 739 Registered: Nov-04 | any suggestion |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3733 Registered: Mar-04 | i would go w/ the RLi 10's...i have heard the 8's before and they sounded amazing. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 1692 Registered: Jan-06 | x2 on the rl-i's |
