Bassman please help,...
Username: Bump05
Hesperia, CA USA
Post Number: 176
hey can you help me out on a box for a 18" havoc its specs are 28-32hz tuning 6 cubic feet is its specs and i got a trunk 36Wx20Hx20D i was trying on subwoofertools but it was getting to deep thanks bro
Username: Southernrebel
Post Number: 3736
its gonna be next to impossible to get 6cuft out of that box....its only 6.83cuft (gross).
is there any chance of you getting alil larger box in there?
say 38"x20"x20"? (or 36"x21"x20"?)
Username: Bump05
Hesperia, CA USA
Post Number: 178
prob a 36WX20Hx21D ???
Username: Bump05
Hesperia, CA USA
Post Number: 179
just make it to fit if you think its worth it cause i dunno if it will pound
Post Number: 3737
build it 36"x21"x20"
port 18.5" x 3.5"....21.75" long. (measure along the port's center-line, it will make an L in the back of the box)
Username: Bump05
Hesperia, CA USA
Post Number: 182
so 18.5 tall and 3.5 wide and how far do i make the wall going back before i curve it ?
Username: Bump05
Hesperia, CA USA
Post Number: 183
can u try to make those plans on subwoofer tools ? please thanks a million you really help :-)
Username: Bump05
Hesperia, CA USA
Post Number: 185
can u please make it on subwoofer tools thanks a million man u really help :-) seriously appreciate it
Post Number: 3739
http://www.subwoofertools.com/forum/ported-box.asp?Ew=36&Eh=20&Dia=11&Xmax=14&Vd =.2&NumW=1&Vb=6&Fb=31&Qts=.515&Vas=1.1018&Fs=29&CE=0
that will do ya.
31hz tuning.
