Audison SRx1
Username: Redwards
im really looking into buying one of these to power my 10' premier sub. what do you know about them?
Username: Alias747
Eclipse Ti, MN
Post Number: 1515
Audison = Top tier amps. Buy it and don't look back. In fact, don't look at your checkbook after you buy it either... :-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3192
audison is great
Username: Paogr
AthensGreece
Post Number: 54
Audison SRx1 is great, but you should use it with a better sub...
Generally, Audison must be matched with SQ subs for SQ setups.
Username: Redwards
Regina/Kelowna, Sask./B.C. Canada
sq?
sorry, im pretty new with the car audio stuff.
Username: Juliob
Post Number: 3202
sound quality.... GOOD sounding subs, not loudness and noise
Username: Redwards
Post Number: 7
and as a recommendation?
Username: Cavsmaxima
New York United States
Post Number: 518
kicker L7s awesome SQ lolol. just kidding..
Username: Van_man
Boston South, MA
Post Number: 1176
Look at jl w6
Post Number: 521
Reid my bad about that i just remembered you said you didnt know much about this stuff. I was joking around, L7s are SPL subs which are basically big in bass and lack Sound quality.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 454
BTW, SPL=Sound Pressure Level which means loud and boomy and doesnt necessarily have sound quality (SQ)
Username: 420alldaylong
Post Number: 726
Get the Q from www.ficaraudio.com you will be very happy.
Post Number: 727
Audioson makes badazz amps.
