Lights dimm help?
Username: Pmpninachevy
Appleton , Wisconsin USA
alright i have 2 12" JBL p1224's 400rms 1,200watt peak and a memphis class d mono block amp(D1100)
and my lights dimm horribly wat size cap should i get??????
or shuold i jus go with a high perf alternator?
Username: Adddisorder
West palm, Florida
Post Number: 1658
get an HO alt. you dont need a cap.
try looking for alts at
knukonceptz.com and 4alterstart.com
some say excessiveamperage.com
or search for iraggi alts.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9786
http://wickedcases.com/caraudio/charging.html
http://wickedcases.com/caraudio/capacitors.html
Post Number: 9
I have looked at all those web sites thank you for the help but i have come to the conclusion that my vehile is not able to support a h/o alt.. so now im stuck with buying a cap?
Username: Ctmike
Ct.
Post Number: 2241
have you tried calling/emailing one of the companies?
Post Number: 12
no i havent, but i have foudn one that is one year off and i asked my father becuase he is a mechanic and he said that theres s differnce bettween them
thanks
i have my power going to the aux post im gonna go change that to go strieght to the battery
West palm, Florida
Post Number: 1673
email or call the companies they dont list an alt for my car but they all make one.
Post Number: 17
thanks i just got done switching my power wire to go from the AUx post to teh actully battery and so far that has done it.... becuase i was looking at the fuse box hooked up to the aux post and it was for the head lights, abs, and running lights n such... so i figured that should solve one of my problems for now
Username: James3146
Portland, OR USA
Post Number: 25
Call Wrangler NW power products they claim to have a Upgrade for every alternator.
