Good Low Brand Amps?
Username: Devastation101
Post Number: 179
What are some good no name, low brand amps...if any? I was looking at a BOSS amp, *chuckle*, just got kinda suspicious of what it could do. I'm always told that the BRAND of an amp is NOT important, but I fail to believe that!
Username: Logan__tille
AudioqueUSA
Post Number: 2278
Do boss amps even put out half of there rated power?
Username: Ctmike
Ct.
Post Number: 2231
if i would ever go with a budget amp, the lowest i'd go would be a hifonics.
Username: James1115
Ct
Post Number: 7239
instead of buying a new bad amp for $200 why not buy a good old amp for $200. Check ebay, you can get some very good old school amps for cheap:-)
AudioqueUSA
Post Number: 2280
Theres an idea^^
Post Number: 181
That is a smarter idea! Thanks
Username: Extrmndor3
Life is GOOD, Ill Us
Post Number: 2417
lanzar optidrive the only low end amp that really push wat they say also th e OL skool sony amps are pretty decent they have their bass boost at 30hz very impressive thats why they sounded soo boomby
