I currently have two single LNBs for 110/119 and two single LNBs for 82/91 hooked up to 4-diseq . How do I use Dishpro LNB with diseq? how exactly does twin DP LNB work as compared to 2 single LNBs? Can DP be hooked up to diseq? I'd like to hook up 61.5 in addition to 82/91/110/119
Keep your setup. It would take a lot of work to get a DishPro LNB to work. These are good if you are using only 1 dish for two sats but combining them takes a lot more work. With your current setup all you have to do is use different DiSecQ and add the 61.5
