New member Username: Feelit3Post Number: 8 Registered: Oct-06 | i have a friend that has two 12" kicker L7's mounted in a super bass probox, its pushed by a kicker kx1200.1 amp. both subs are powered right now. would it be louder if the amp only powered one of the L7's??? |
Silver Member Username: KenwaPost Number: 505 Registered: May-04 | No either way but dual 2 or 4 ohm voice coils? |
Silver Member Username: KenwaPost Number: 506 Registered: May-04 | didnt bump. |
Silver Member Username: KenwaPost Number: 508 Registered: May-04 | still nothin |
New member Username: Feelit3Post Number: 9 Registered: Oct-06 | dual 2ohm |
Bronze Member Username: Feelit3Post Number: 11 Registered: Oct-06 | dual 2 ohm |
Silver Member Username: KenwaPost Number: 512 Registered: May-04 | definetly not, 1200 watts on any L7 is not a good idea. |
Silver Member Username: Naledge503Currently residing in ..., Oregon USA Post Number: 446 Registered: Jun-06 | thats the problem right there. You got 2 DVC 2ohm subs and that amp puts out full power at 1 ohm. each sub is seeing about 300 watts each and they are rated at 750rms each |
Silver Member Username: GrebnereonPost Number: 397 Registered: Mar-06 | that L7 would turn into a heavy piece of trash pretty fast with 1200 |
Silver Member Username: CavsmaximaNew York United States Post Number: 460 Registered: Aug-06 | too much power for one sub thats rated at like 1458 RMS |
Bronze Member Username: Feelit3Post Number: 13 Registered: Oct-06 | ok so what is the best way to wire it all? and what should the settings on the amp be? |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1852 Registered: Jan-06 | If it was me but this is only if you had an upgraded electrical system, I would wire it all at .5 ohm load but start with the gain all the way down and creep it up slowly. Here is a link it will help you adjust the voltage with a DMM do it until it is around 35V and you will know you have the right output and won't fry the subs. If you cannot achieve the desireed output because your input voltage is too high then you will need to find a way to cutdown that also, just an idea...Polo. http://www.subwoofertools.com/forum/setgain.asp |
