Are there new keys for DN
Username: Playa_zihua
Post Number: 18
just wondering if there were new new keys im getting wait on pic
Username: Mc_sunny
Post Number: 490
Updated: Wednesday, October 18 2006
Dishnet Keys, Provider 0101:
Key0: 64 E1 5C E3 F3 B6 A0 54 C2 E6 3D 1C 98 95 8C FD
Key1: 1E 3D 0A 09 C0 C4 C6 A0 01 04 96 29 83 CD 7C CE (active)
Username: Gaganji
Key1: 1E 3D 0A >>09<< C0 C4 C6 A0 01 04 96 29 83 CD 7C CE (active)
I just changed the 09.
Username: Wisbang
Ontario Canada
Post Number: 9
i put the latest keys in and only get update do i need a new bin
Username: Rexandpansat
Dish Network
key1: 1E 3D 0A 09 <-- (09 changing to 18) on Pansat 2700A with Autoroll OFF.
My bin file is X-87BL
API: 2.74C_EUBX
Boot ver: 6.2
27. Sept. 2006
Any idea ?
Thanks in advance
Username: Donyahelwa
Post Number: 147
if it was working today. I don't think you need a new bin. double check the new key; this is the only solution, if you had it working today!
Post Number: 7
Thanks D.
The problem that started this evening is:
After I entered new Key 1 with Autoroll OFF, the
4th field 09 is changing to 18 in a few seconds !
Looks like DN is doing something very smart (changing 09 to 18).
Username: Albino_midget
Post Number: 243
maybe the latest bin will fix that
http://www.future-fta.info/Forums/showthread.php?t=35261
Username: Derrick
Post Number: 17
I am using 09 still and working fine on my viewsat and pansat is it going to change to 18 soon??
Username: Jwl1
Post Number: 9
Dish Network
My Pansat auto rolled to 18 also. However, it wouldn't work with the 18. Therefore, I had to change it back to 09.
Username: Hanz
Post Number: 8
How do you keep the number to stay 09? It changes to 18 every few seconds.
Username: Pitbullk_9
the dishnet keys don't work. need some help
thanks
Username: Jenifer_contreras
Tampa, Florida USA
Post Number: 332
This is for CHARLY
Username: Jwl1
Post Number: 10
Do you have your auto roll off? If not, turn it off. Make sure that you are saving it before exiting. Hopefully, that will solve your problem.
Username: Ekhan
i used that key for my multistar pantec ultra and it worked fine, but i had the same problem it keeps changing to 18...
I went to change it to autoroll off and i found 3 of
em
dishnet autoroll
BEV autoroll
Globecast autoroll
i turned them all off is that correct, or do i turn only 1 of em off
so far it hasnt changed to 18 yet
Username: Lklives
Post Number: 4778
New Dishnet Keys... 19 Oct 8:00 PM (EST)
Key 00 .....changed tonite..
AD D4 B6 11 BC FE 23 73
23 8E D1 1E D9 5A C7 D0
Key 01
thanks for the new keys LK
Username: Jalaj69
Norcross , Georgia USA
Post Number: 37
Please someone help!!!
MY dish recently fell from the roof and i did get it fix but now the prob i have is ECHO 3 does not pick up any signal it keeps on changing the percent from 30 to 90% it does not stay the same! i don't know what to do.....someone please help!
Username: Ouchi_collashi
Post Number: 62
The lnb is probably loose. Wedge a piece of paper on both sides. Make sure the two pieces of paper is the same thickness.
Username: Santoshwadhwa
Key 00 Has Changed This Evening At 6.30pm Here R The New Keys Tried And Tested
Key 00
Ad D4 B6 11 Bc Fe 23 73
23 8e D1 1e D9 5a C7 D0
Username: Jalaj69
Post Number: 38
LNB? where is that located "ouchi collashi"......
all i know when i go to ANTENNA SETUP under ECHO 3 the part where it sayd DiSEqC #--and pick #3 the signal strength level does not stay study! ....i don't know what to do..
Username: Nydas
Post Number: 750
Updated: Friday, October 20 2006
DN, Provider ID 0101:
Key 00:
AD D4 B6 11 BC FE 23 73....23 8E D1 1E D9 5A C7 D0
Key 01: (active)
7E 87 A1 1F 5D 3E 3E 47....57 C6 1A 36 FC 83 3C C7
Bev Keys, Provider Id 0901:
key00: (active)
81 32 86 60 73 26 01 DB'.E5 3B C4 42 3E 1F 41 64
Key01:
60 05 EF C2 B5 F7 AE 96'.BB 38 20 8F FD FE 08 44
Username: Brown_souljah
everytime i put new keys on my reciever.. i have fortec.. the keys change back to the old oness... please advice me how to fix this problem.. thanks in advancee.. please private msg me thanks
Username: Ekhan
i tried the keys anyone know what im doing wrong??
i tried the keys from last week and they worked fine.
Is something wrong with dishnetwork or is it my receiver or something???
Username: Nydas
Post Number: 765
Khan Baba: Turn keys off and autoroll off. Put in the correct keys - Nagravision ID 0101 for DN or ID 0901 for BEV or both. Put in both Key 00 and Key 01 in each. Make sure you press OK to SAVE. Then Exit, change Key Off to Key on, leave autoroll off, go back into Nagravision 2, recheck both sets of keys, SAVE again, Exit, Exit, Exit and you should be OK.
If not, switch off at the back and switch on.
If not successful, post your receiver Model, and Bin version and date and other relavant information , as to when you were actively viewing everything.
Username: Psychmonster
Chi town, Il USA
Post Number: 32
NN...bad advise to turn keycodes off..that will give bad /scrambled almost automatically..I am having probs with 3500sd with newest bl bin...something needs to be tweaked with bl bin x-85bl_061011 361 updated file...disturbed that we have not got past this relatively minor problem of morphing, but everytime charlie sends a minor blem ( and thats all thats left for them except a major overhaul of systemics at ground level, which is prohibitive)once we get this problem licked, then the the other recievers will fall in line...LK I bow to your insistance that BL comes out with fixes after VS..but bottom line we all benefite..still not getting tv with autoroll off and manual insertion of latest dn keys...and I will not talk in ebonics of most contributers to this site...destruction of the English lanquage...last precious vestige we have left...we have enuff (ok are you happy) people that cannot even ask a question properly on this site..
Username: Nydas
Post Number: 768
psychmonster: When you are in Nagravision 2 key entry mode, there is no TV and no "bad and scrambles channels". In fact, if you have the wrong keys, you do not get TV. There have been many people with "minor problems of morphing" and for people who keep on having problems in spite of entering correct keys, this is the correct way - enter the keys with keycode off and autoroll off, then turn on the keycode, then exit out and turn off the power and turn it on.
The method that works counts and I have had two desparate people who defeated "key morphing" this way. I suggest you try my method with your 3500sd and watch TV with autoroll off, i.e. IF, ONLY IF, you are having problems. Again, if your receiver is working fine, there is no need to change anything.
The bottom line is - IT CAN'T HURT. That is more than we can say about some incomplete advice that is being posted which ends up with people needing j-taging, etc. This is just a general statement, not directed against your posts or any particular person(s).
Technically speaking, "key morphing" is a significant challenge to BL and other codes, and will probably get worse, before it is solved.
Chi town, Il USA
Post Number: 33
NN...DUHHH...when you go to NAG 2 and save the latest keys and have auto off..and keys on...you should get a pic after waiting...I will try your unorthodox method exactly as stated with IF output intsead of TV output...I will report back in next mail...thanks for the advise no matter what?!!!...just curious...do you have tv and how do you have it?...ciao
Chi town, Il USA
Post Number: 34
NN...sorry for my latest gaf...but sometimes my "Hunter S Thompson" comes out before I think the anwser though..thanks for your insights...believe me, you have helped more people than you know by anwsering my semi- abusive queries...thanks for all past and future abuses...I shoot from the hip...but i get some people rolling and rocking and thats good
Username: Nydas
Post Number: 770
Psychomotor: I trust you are up and running. That's what matters most.
Chi town, Il USA
Post Number: 35
hi NN...actually its psychmonster..its a musical related term..check my web on my intro if interested...no...still down...latest BL autoroll is down..still keeps searching when manual keys inserted from Keyripper..I never thought this latest BL bin 361 would be hung up on just some number switching hocus pocus by DN and Bev on the keys...thought we were past that..
Chi town, Il USA
Post Number: 36
back up again ...after latest update of bl 361 bin for 3500 ...reset and rescanned...all is well...put all my crap in a jar and sprinkle liberally on all crybabies like me and dilute same...but vote those ba-stards out !!!
does anyone have the DN key for colsat 5000
thanks in advance
Username: Hicham
Post Number: 25
roy johns
the keys still the same dosnt change...
Key 00:
Key 01: (active)
zaza mala, i just bought the box and the key above doesn't work, what do u think the broblem is? is there any kind of software needs to be installed?
thanks in advance
Username: Minn_rock
Post Number: 474
roy johns, yes you need to install some software into your box before it can work, u need a bin files and a loader and the cable that come with your box..go here look for your bin and loader..
http://www.dssrookie.com/forums/
http://www.dsscommunity*com/forums/..change the star to a dot...
Username: Super_cool
Post Number: 7
guys the keys are down again for dish net work
any idea?
Username: Lklives
Post Number: 4899
No.. they are NOT down
guys, DN is down.
Do u guys have the keys?
thanks in advance
Username: Bertoro
Toronto, Ontario Canada
Post Number: 265
90 A7 AF B6 6B 41 31 82
42 EC 15 50 E1 15 79 98
active 00
Username: Ustaad_hc
Post Number: 49
NEW KEYS FOR DISH
KEY00: 90 A7 AFB6 6B 41 31 82
KEY01: 7E 87 A1 1F 5D 3E 3E 47
Hc thanks but the code does not work
are u sure it is for dish net?
Username: Ustaad_hc
Post Number: 51
YES it's working fine
Post Number: 7
i dont know then because i just put the keys in and it doesn't work. is there any other suggestions?
thanks in advance
Username: Ustaad_hc
Post Number: 52
when you change keys make sure you save it first before exit. (Press on remote OK for save keys)
thanks!
Post Number: 9
Hc, i did save it and it still doesn't work.
usually it does work right away, any other suggestion?
thanks
Username: Str_kid00
Brampton, Ontario Canada
any1 got keys for dish net?? tha 1 hc givin aint workin... my mom wants to watch sum desi stuff lol.. help plz?
Username: Ustaad_hc
Post Number: 53
what kind of reciever you have?
make sure you have latest bin file.
Post Number: 10
colsat 4000
how aften do i need to install the bin file?
thanks
Username: Minn_rock
Post Number: 479
roy johns , recheck your keys to see if it still the same,if the keys have change turn off the autoroll,enter the keys again..
Post Number: 11
the keys havn't changed, it is still the same.
all the keys that are usually posted, works fine in my reciever.
i have no idea whatz happening right now.
thanks anyways MINN ROCK
Post Number: 12
it seems like fahad mohammad has the same problem, the key doesn't work on his reciever either.
Username: Minn_rock
Post Number: 480
the last option,turn it off from the back of your box wait for 1 min,than turn it back on..see if it work..
Post Number: 13
thanks guys for all the help. i guess its just a bad luck. maybe i would try the next code that you guys would post later on. but for now i guess i will just chill out.
Username: Wildman95
DN
90 A7 AF B6 6B 41 31 82 42 EC 15 50 E1 15 79 98 active
7E 87 A1 1F 5D 3E 3E 47 57 C6 1A 36 FC 83 3C C7
BEV
45 6D DE 1A C3 71 83 CB 76 F0 E6 AA E1 16 D4 A1
73 43 7B 89 F1 34 92 C6 81 56 AD 59 02 0F C4 68
Username: Wildman95
Nagra2 Keys
Dish Provider 0101: Last Updated (Oct23 8pm)
Key0: 90 A7 AF B6 6B 41 31 82 42 EC 15 50 E1 15 79 98 (active)
Key1: 7E 87 A1 1F 5D 3E 3E 47 57 C6 1A 36 FC 83 3C C7
Bev Provider 0901: Last Updated (Oct23 2pm)
key0: 45 6D DE 1A C3 71 83 CB 76 F0 E6 AA E1 16 D4 A1
Key1: 73 43 7B 89 F1 34 92 C6 81 56 AD 59 02 0F C4 68
Username: Str_kid00
still aint wrkin for me.i duuno y i bin tryin all the keys u guys r postin turnin it on from back an all.. but i guss it gun not work
Username: Nydas
Post Number: 773
Fahad: You have not posted enough information.
1. Name of receiver
2. BIN in the receiver and BIN date
3. How many dishes, switches.
4. What was working well last and when - specifically when did you have, ZTV, ZCine, B4U, PTV, QTV and SET - all of them together on the same day?
Username: Nydas
Post Number: 774
roy johns: It is frustrating if things don't work. However, Minn Rock has tried to direct you well. Sometimes, DN uses "key morphing", giving exactly the kind of frustrations you are expereinceing.
You are in a desparate situation. I suggest you try one more time my instructions two days ago to Khan Baba. You may also read all the converstion I had afterwards with psychmonster.
https://www.ecoustics.com/electronics/forum/home-video/279790.html#POST902479
Username: Johnner
Miami, Florida
Post Number: 845
Posted on Tuesday October 24 2006 - 09:51 am: by OSVALDO SERRANO
Nagra2 Keys
Chi town, Il USA
Post Number: 39
the day that BL and VS put out the autoroll fix back in Sept..I said that charlie had shot its wad and I felt that we were going to see a long uninterrupted time of prosperty for FTA...still feel that way...Charlie has spent millions trying new maps and then having to reconfigure existing customers so they wont be affected ...I think they are gonna wait for next technology in the future and are basically just gonna try and morph keys, because the underlings can say to the bosses that they are still doing something...so enjoy for awhile longer...and to those endless questions about new keys...get a reciever that is authentic and has a legitimate autoroll bin...stop wasting the precious time of the mods and the people that can read!!!...as one of the greatest mods of all time once said "Just seek and ye will find" look it up in the good book..
Username: Str_kid00
sry i dun no any thing bout tha bin or stuff im new to this but i got coolsat4000. all tha chanels except for z cine were wrkin last night bfore 8pm i dun no afta that cuz i went sum were wen i came back at like 11pm they wernt workin... the keys seem to not work im having tha same problem as roy johns .. i tried turnin it off from back and on again.. i tried auto roll off and every thing nothin works . any other suggestions?
Chi town, Il USA
Post Number: 40
gotta tell ya...I am stumped...looked up all co_l sat data on future fta and google.no go...I am sure there is a copycat bin for you....apparently this is an older model..not familair with CS..who does your mods and who is your cool-sat guru...they must have someone who speaks for them instead of just duplicating the work of the BL and VS heads.....cool_sat peps...speak up and help your fellow subsciber
Chi town, Il USA
Post Number: 41
fahad mohammad ...one last thing....my good book and yours is not that far apart.....but.....only when Christians say for "an eye for an eye" in the bible, we do not act on it in general...maybe Isreal and Bush have recently blurred that, but please endorse the middle ground and not the alternative..we will change our leadership under rational ways... not under a threat from radicals...and I state that you are not one , but some may be looking...so thanks for participating in an american dialoge...welcome
Post Number: 267
fahad, make sure your 10,11 is correct--next change will be 20,21
10- 90 A7 AF B6 6B 41 31 82
11-42 EC 15 50 E1 15 79 98
20- 7E 87 A1 1F 5D 3E 3E 47
21-57 C6 1A 36 FC 83 3C C7
Chi town, Il USA
Post Number: 42
just saw you are in Canada...same applies...welcome when you contribute to our mutual countries..cool-sat is up on autoroll..keep watching...you will be informed...cheers
Username: Str_kid00
yo thnx to all yall for ur help it finally worked ,,,... i rlly don no how i jus put in tha keys again and it seemed to work.. thnx again and psycho ty for tha nice comments
Post Number: 14
thanks u guys
finally figured it out
i had to put the old code back in the reciever, saved it, turned off the reciever and then i re-entered the new code.
it worked
if any body has the same problem, try it. it works
thanks all of u guys
Username: Ustaad_hc
Post Number: 54
finally u got it.
Post Number: 15
Agine it's down.
Post Number: 17
is it just my reciever or is DN down again
thanks
Username: Tekomi_elhoyo
Post Number: 25
Nagra2 Keys
Dish Provider 0101: Last Updated (Oct25 1pm)
Key1: 7B D5 40 8C 28 9C F5 17 00 F2 26 43 EF C7 27 A3 (active)
Bev Provider 0901: Last Updated (Oct25 11am)
key0: 46 9A B6 A9 73 10 40 81 FA 5E 60 78 C2 0D ED 5B
Key1: 3D 0F 7C F9 38 CD D2 6E A2 91 0F 53 E6 17 23 87
Post Number: 18
thanks Tekomi Elhoyo
Post Number: 27
You Welcome
Enjoy while it last
Post Number: 19
DN down once again. New keys?
thanks
Chi town, Il USA
Post Number: 43
still up and running over here...
dn
bev
Username: Evilnip
Winnipeg, Manitoba Canada
Post Number: 16
http://www.dssevolution.com/forums/showthread.php?t=84335
new keys for dish... part 2
Username: Derrick
Post Number: 21
I just put those keys in psychmonster was working fine but down again.
Post Number: 20
psychmonster. your code was working fun just a while a go, but it is down again.
Username: Evilnip
Post Number: 17
new keys for dish network
Key0: DED7133377267CE840BF9C7EA04F2C84
Key1: 7BD5408C289CF51700F22643EFC727A3
Post Number: 21
thanks veryevilinip
Username: Lklives
Post Number: 4957
BELL EXPRESSVU
Bell ExpressVu: Last Update: 10/25/06 11:10:00
FA 5E 60 78 C2 0D ED 5B (Active)
DISH NETWORK
Last Update:10/25/06 17:32:00
Idea Key 0:
Idea Key 1:
00 F2 26 43 EF C7 27 A3 (Active)
GLOBECAST
Last Update:9/12/2006 11:30:00
00 Key
EB 4A C4 1A 45 5B DD 23
54 7E EF 4B 3A BF 4D 62 Active
01 Key
83 20 3C A8 E5 7B 93 A6
7B 12 67 AB 40 62 03 B1
CAS Line Code Info
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1
Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
Username: Mh4ever
great! its working
Username: Evilnip
Post Number: 18
LK, believe it or not,they changed the keys again for dish,i entitled it as dish keys part #2,lol.
Post Number: 23
they changed the keys agian
any new keys
thanks
Username: Evilnip
Post Number: 22
Key0:E680E601DB7DEE4D9B12EC906227AD26
Key1:D2936944CC94E3A757B4AF937A15916B
new dish keys
Post Number: 24
DN down again
any new Keys?
thanks guys
Username: Lklives
Post Number: 5125
keys have NOT changed..
Nagra2 Keys
Dish Provider 0101: Last Updated (Oct27 3pm)
Key0: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 (Active)
Key1: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD
Bev Provider 0901: Last Updated (Oct29 7:05 pm)
key 0=52 72 96 A9 B1 49 Cb C4 OA E2 4F A8 F9 OB 19 53(active)
Key1: 09 74 B7 EF FE 60 51 9E 89 E6 2D 12 62 FE FA 19
Chi town, Il USA
Post Number: 44
LK is to civilised to say it but here goes my uncivilised reponse...most questions about new keys are from newbies that may not understand that they do not have to keep programming new keys every two days after morph, but Roy Johns and all the rest...please use your grey matter to do a little of research...you have to be getting tired of asking the same question over and over, and we are just as tired of answering it..get a decent reciever and load the latest autoroll bin...you are the last idiot ( sorry but no other way to say it) that has not downloaded key ripper or key grabber and has latest keys at your fingertips and / or has a useless piece of crap reciever that does not support latest autoroll..get with it and leave us alone...
Post Number: 25
hi psychmonster, if you dont have the keys just shut your mouth.
i am asking for keys from people who are willing to help.
no need for your stupid comments retard.
save your BS for some other time, nerd
Chi town, Il USA
Post Number: 45
RJ...the only time I have ever seen one of your quires was to ask about the latest keys...ok...you want help...here it is...click this below and download...now you will never have to overload your meager grey matter...the keys will magically appear...amazing!!! www.digitalevolution.tv/
Post Number: 26
hey psychmonster, i will be the man and thank u for the help.
all you had to do was to give me that website.
did not have to write all the comments you wrote.
Username: Wildman95
Nagra2 Keys
Dish Provider 0101: Last Updated (Oct31)
Key0:
3E 9D 55 0B 31 C6 76 1A
5A 8C B9 AC 32 4B E5 10
Key1:
6F 03 DA 9D 0E D2 6D BC
B3 17 6B 73 33 BE E7 3D (Active)
Username: Wildman95
Nagra2 Keys
Key0:
Key1:
key0:
Key1:
Username: Iwishiwaskevinfederline
hey do nagra1 keys change...and are they needed
Username: Minn_rock
Post Number: 555
david salas nagra 1 is dead a long time ago,u don't have to worry about that..just the nagra 2 that need to change keys....
Post Number: 7
thanks .. and you can call me David
