Cheap 15" woofer replacement suggestions.
Username: I_likes_da_bass
Bentonville, AR USA
Post Number: 77
I just bought a Pioneer VSX-816-S Receiver and I was given a pair of 15" woofers in a box that have horn tweets built in but one of the 15's is blown. I have been searching for very cheap replacements and so far all I have found was this place http://www.electronixwarehouse.com/home/woofers.htm The very bottom woofer is only 55 dollars but I don't know if it's one that will just fall apart once I get power to it.
I would appreciate any suggestions for some very cheap replacements that will work good off this receiver. Thanks much.
Username: Project6
Post Number: 11396
Are these woofers meant for Car Audio?
Bentonville, AR USA
Post Number: 78
No, this is for home audio.
Username: Project6
Post Number: 11399
That speaker should work, but make sure you have the proper impedance on your speakers or you will risk blowing your receiver more than your speakers.
There is also partsexpress.com, for your DIY stuff.
Bentonville, AR USA
Post Number: 84
Thanks alot, I'll check that out.
