HELP Viewsat Extreme!!
Username: Nickb
New York, New York USA
Post Number: 103
Hi
I was changing the audio settings on my Xtreme...when it froze...I turned off the power switch and turned it back on again but it just reads - - - - then boot then end ...and stops at end...
I tried to reload the current bin but I when I click PC->STB and turn on the Extreme it doesn't accept the new bin...just says boot then end and stays at end...
Can anyone help me?
Thanksss
Username: Jenifer_contreras
PIMP Member, Yokosuka, Ka...
Post Number: 624
Try to re-flash with original bin,then with current.
Username: Nickb
Post Number: 104
I'm trying to load the v2068 factory but it's doing the same thing...let me try again...do you have any suggestions of which factory version to use??
Thanksss
Username: Nickb
Post Number: 105
OKK seems to be loading the factory v2068...hopefully it works all the way...THANKS JENIFER!!! :D
Username: Nickb
Post Number: 106
Works!! Thanks Jenifer~!
Post Number: 629
no problem! and double check yor current bin (maybe it's for platinum),this is from mine...work perfect on Bev.
Username: Nickb
Post Number: 107
Thanks...will do :D
I was trying to change the audio setting to Dolby Digital on one channel and it just froze up...and then rebooted and got stuck on end.
I don't know why that happened...but it's all good now..thanks again :D
