How to hook up a cap?
Username: Caraudio
Toronto, Ontario Canada
Post Number: 749
Ive noticed that theres only a + and - at the top. Using the power and ground into thoes 2 areas on the cap is there another set of * - at the bottom that are "outputs" so to speak or do i have to stick 2 sets of power wires into that one slot one in and another one in the same + to the amp.
Username: Qbenjamin
Florida
Post Number: 14
The Cap's only have 1 input source, and that is at the top of if. Feel free to run as many power lines from it as you want. I would always suggest making a different ground source for seperate units/amps/caps.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3239
do you have a HO alt???
Username: Caraudio
Post Number: 750
how would i run a power line from it. Does it have n output?
Username: Van_man
Boston South, MA
Post Number: 1162
Wire it like this.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 443
That looks like a bangin azz system. I guess you have to be sponsored by sony to get that kinda stuff
Username: Caraudio
Post Number: 751
how would i be able to put 1 wire in and at the same time get another out?... guess this will take some time..
Username: Adddisorder
West palm, Florida
Post Number: 1712
why are you even putting a cap in i know you got a stock eletrical?
Username: Nuck
Post Number: 4521
Hi. I want my high end home stereo to sound like your bass heavy stupid piece of crap car stereos. How do I start?
Username: Van_man
Boston South, MA
Post Number: 1173
use a distribotion block, or get some ring terminals. You can get copper ring terminals at a battery parts area. They will take to up a 4 awg wire.
And Nuck, Whats your budget?
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 452
Sony had good equipment at some point? lol Nice sense of humor Marc.
Rock Vegas, NC US
Post Number: 453
sony HAS good equip, just not good audio equip
