ANYONE MISSING CHANNELS ON DISH NET?
Username: Evilnip
Winnipeg, Manitoba Canada
Post Number: 19
anyone missing any channels on dish network after inputting new key?
missing court tv,and a few others.
says its scrambled and yet it has full strength.
Username: Mc_sunny
Post Number: 531
Turn OFF ur reciever from the back and turn it back ON after 2 min...see if that bring ur channel back
Username: Destine1983
Montreal, Quebec Canada
Post Number: 156
I recently rehooked up my dishnetwork onto my box,now I have dish and bev,I've had them before,never moved my dishes.
Now,some channels work and some don't.The ones that I put on the tv,Baby,NIckjr,any in the W's it says scrambled bad channel,then it does a tp update and the channels disappear.I understand what is happeneing when that happens,but it happens on every channel I turn to on Dish.Any ideas on what is happening?Yes I turned it off and back on.Same prob.
Username: Mc_sunny
Post Number: 533
Julie First thing u need to do...TURN OFF the AUTO TP UPdate..once u do that, the auto tp update won't show up again....and now give me the list of those channel ur missing and can u please tell me wut kind of reciever u have ?
Post Number: 157
I am using Pansat 2500 a(clone).
Not sure of all the channels I lost,but I have been trying to get mostly the cartoons for my daughter.Here are some channels that I've recently lost
BABY
NICK
WSIU
WSTM
WSTQ
WSYR
WSYT.......i CAN GO ON AND ON.iT HAPPENS WITH THEM ALL.
Username: Mc_sunny
Post Number: 534
U need to turn of the Auto TP...GO TO UR MENU and User Setup... at the bottom u will see Auto Tp..Turn That OFF
Then u need to do Blind scan...GO TO UR Menu Insallation then u will see Blind SCAN and then select ur sat and hit ok...let it scan all the way once it is done exit and see if that sloved ur problem ...Good luck
Post Number: 158
Hey Mc Sunny,thanks for the tip.I did just that.Working now,my hubby is now watching his South Park,sure he is happy 8>)
Username: Ryersonresurrected
Post Number: 111
Upload Upload
Post Number: 159
Lmao Ryerson,my hubby loved that pic.
Post Number: 140
Post Number: 178
Post Number: 179
Post Number: 180
Username: Tutu1712
Post Number: 10
Hi! Ryerson, I have missing channels like 584,585,586, 471, 472,and some of my popoular 610- 620. I have Ariza 700 and have latest bin 284. I have 61.5 and 119. The setting for Echo 3Ku are :
2 TP 12603 V20.000
3 LNB POwer ON
4 LNB Type Standard
5 LNB local Freq 11250
6 22KHZ off
7 DiSEqc = 2
8 Legacy sw none
I could get most of the english channel but NO indian channel
