Okk lil bit more help
Username: Icecreamman5687
Post Number: 70
okk soo i went and re wired my subs to 4 ohms cause it was simple right now...it finnaly works....but just wonderin on all the tuning for the amp. it has on the side for nobs; level(9v-.2v), phase(o-180) lowpass(35hz-250hz) bass eq(odb-18db) and sub sonic(15hz-50hz) any help plz
Username: Ctmike
Ct.
Post Number: 2158
gain (level on yours)-set to match the preout voltage of your hu
lowpass-80 or so
bass-i don't use mine, if i do it never goes higher than 2 out of 18
sub sonic filter-if ported box, set to below the tuning of your box, ex. 36hz tuning, set to 30-36. sealed box just don't use it.
Post Number: 71
thnx man
Username: Thomas_g
NM
Post Number: 1923
ctmikeFTW!!
lol
Username: Ctmike
Ct.
Post Number: 2159
huh? still don't know what that means:-)
Post Number: 72
how do u find wat ur level of ur hu has
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2394
hey its your amp hifonics?
Post Number: 73
ya it is
Username: Brynm
Prince Albert, SK Canada
Post Number: 219
what hu do you have?
Post Number: 74
pioneer premier DEH-2700
Username: Thomas_g
NM
Post Number: 1925
ctmike
FTW Þ For Tha Win he he
Username: Ctmike
Ct.
Post Number: 2160
thanks tj, do i feel dumb.
and kris, is that the right model number cause i couldn't even find it on the pioneer site.
Post Number: 75
its was i found off of ebay.... cause its a year or 2 old
Username: Ctmike
Ct.
Post Number: 2162
sure it's a premier? found a deh-2700 but it's not premier. silver with green buttons, round knob on left, four way button on right? if that's it then your preouts are 2.2v.
Post Number: 76
dam im sry they put the wrong model down on the site how about premier
DEH-P670MP
Username: Ctmike
Ct.
Post Number: 2164
still 2.2v.
Post Number: 77
okk thnx
Username: Thomas_g
NM
Post Number: 1927
LoL Ur WeLcOmE...
MEMEMEMEME
MEMEMEMEME
Username: Thomas_g
NM
Post Number: 1928
YEAH!!! Im GeTtIn PrO At DiS ShIzZnIt
Username: Thomas_g
NM
Post Number: 1929
check out these FI CAR AUDIO VIDS.
Username: Thomas_g
NM
Post Number: 1930
Kool i learned how to do that too!!
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 685
what about phase? 0-180? what do you guys usually put for that?
Username: Bernymac
Post Number: 687
I just got back from tuning my hifonics bx1500d for my type R's. Sounds so much cleaner now =) and it still bangs. btw, using this system till I finish my other project :D. Thanks ctmike.
Username: Ctmike
Ct.
Post Number: 2167
no problem:-)
Post Number: 78
yah so i got the amp hooked up i tried to tune it a lil bit but i just doesnt hit as hard as i expected... it seems like my kenwood 1000watt amp hit harder...im not sure
Username: Ctmike
Ct.
Post Number: 2172
what amps/subs you have? and type of box?
Post Number: 80
i have 2 alpine type r a hifonics brutus bxi1606D and the box i know is sealed had a buddy build it he says its all to spec for a sealed box
