Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 44 Registered: Jun-06 | has anyone ever had this kenwood a,p? how are they?http://cgi.ebay.com/NEW-KENWOOD-KAC-9152D-MONO-CHANNEL-AMPLIFIER-AMP-CH_W0QQitem Z9743500949QQihZ008QQcategoryZ79828QQrdZ1QQssPageNameZWD1VQQcmdZViewItem |
Gold Member Username: IlluminatorUSA Post Number: 4818 Registered: Apr-05 | Trash. :D |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3071 Registered: Dec-05 | forget about kenwood man, bad power supplies |
New member Username: Bobid77Post Number: 6 Registered: Oct-06 | I have a Kenwood KAC-X812D and it is really powerful, the only problem is it draws a ton of Amps compared to other amps with the same Watt value, it dims my lights like crazy where other amps such as Boss wont |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 9690 Registered: Jul-05 | ^LLOOLL...the kenwood is not that powerful...ur lights dim because u dont have the electrical system to power it.. |
Silver Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 158 Registered: Oct-05 | dont get kenwood amps |
Silver Member Username: JohammbassIRL Post Number: 447 Registered: May-06 | Doug, maybe it draws a lot of amps because is very inefficient, lol? Or maybe the stuff that you compare it to is total crap? Zapco C2K 6.0 - 3x30amp fuses, 2x150w@4ohm stereo, 1ohm stereo stable, THAT is what you can call - drawing some current Fak Kenwood And what is Boss anyway? LOL |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3119 Registered: Dec-05 | IDK why they don't give Car audio tutorials at highschool, that should be a good class. Damn too many newbies talking trash |
New member Username: Bobid77Post Number: 8 Registered: Oct-06 | My Kenwood has very good sound, but it dims my lights like crazy compared to the Boss Audio GT1500D, I know it draws a lot more current and i KNOW my alternator cant kick it. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3125 Registered: Dec-05 | both sucks bro, end of the story |
Bronze Member Username: Bobid77Post Number: 12 Registered: Oct-06 | Which Amp would be good for 500 watts RMS at affordable prices? |
Bronze Member Username: Motomattic3Post Number: 40 Registered: Oct-06 | JL E1400d has good power and you can find it for cheap on ebay |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3139 Registered: Dec-05 | DOUG JL 500/1 |
Bronze Member Username: Motomattic3Post Number: 50 Registered: Oct-06 | JL 500/1 all up thats what i want to upgrade to but still got 1.5years left on e1400d warrenty |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 150 Registered: Aug-06 | yea my lights dim to and i have a 9201d kenwood amp its not that loud but i guess its ok.. i have heard way loudewr but anyway why do my lights dim i know its something with the volts or something .. if i were to get a better amp like a hifonics amp would it fri my alt plz let me know |
Bronze Member Username: Bobid77Post Number: 18 Registered: Oct-06 | If you buy a less expensive amp, the amperage draw will be less and wont dim your lights no where near as bad. My friend has a Boss audio amp that has a smaller amperage rating than my Kenwood and our rms watts are the same. Are cars are identical and his lights dont dim but mine do. From what everyone says here Kenwood sucks. |
Bronze Member Username: Motomattic3Post Number: 58 Registered: Oct-06 | get a capacitor for it and your lights will stop diming I got a power acoustik 2 farad cap that will stop it for $60 if your interested. plus it lights up and shows you the voltage. |
Bronze Member Username: Bobid77Post Number: 20 Registered: Oct-06 | I recently installed a 2.4 Farad Cap and it made no difference what so ever in the lights dimming |
Bronze Member Username: Motomattic3Post Number: 68 Registered: Oct-06 | get an optima battery then or upgrade your altenator. btw what farad cap do you got |
Bronze Member Username: Bobid77Post Number: 21 Registered: Oct-06 | Legacy 2.4 Farad |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3176 Registered: Dec-05 | forget about legacy |
Silver Member Username: KenwaPost Number: 486 Registered: May-04 | Less expensive junk like boss and legacy doesnt dim lights b/c they dont put out anywhere near the power they claim, therefore less current draw. And for the price you can buy kenwood on ebay for it isnt terrible. I have seen a few bench tested and they were actually putting out what they were supposed to. I dont remember the models though. |
Bronze Member Username: Bobid77Post Number: 22 Registered: Oct-06 | That makes sense, ill keep my Kenwood, I honestly like it, it has very clean power. I would like to buy a H/O alternator, but i dont see how they can fix the problem, Are they fast enough to react to produce the current when the amp needs it? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3181 Registered: Dec-05 | they put more amperes to your ride, for electrical system and all those stuffs. |
Gold Member Username: CtmikeCt. Post Number: 2180 Registered: Feb-06 | http://wickedcases.com/caraudio/charging.html |
