I would like to build my own box but donw know all the specifics to do so. I was thinking about building 2 seperate boxes to go under the backseat of an 03 quadcab ram. I would like to put the assassin 10" subs in it but i want the right box to make them sound good
I have a 15" Crossfire BMF, a 12" Pioneer and 2 10" Audiobahn subs, all powered by a 250W Rockford Fosgate, and 2 200W Pioneer amps and I was wondering if anybody could help me design a custom enclosure for everything but the 12" sub. Thanks
Resonant Engineering...,
Fort Worth...
Fort Worth, ...
Post Number: 1440 Registered: Nov-05
Honesntly if I were you I'd only run the two 10s or the single 15" ... mixing and matching subs is not a good idea.. the only way to make it work is if you get a cross-over and sent the 10"s the higher hz while setting the 15" to remain on the lower notes..
