Something extremely strange
Username: Yanniss
Post Number: 89
i have viewsat running 07 version today the keys changed mine did not chnage the keys but still running with the old keys while other receiver viewsat i have i got to change the key . i chheck the new working keys with the one i have running no way still running with the old keys any explanation
Username: Jojogun
Fairfield, CA United States
Post Number: 205
Please.......state your case a little clearer because I have no idea what you're trying to say. Maybe someone else does.
Username: Lklives
Post Number: 4999
The other will change and autoroll to the new keys..and keys changes are NOT an IMMEDIATE thing!
Username: Yanniss
Post Number: 91
okkk the key that working in my viewsat as of friday are :Key0: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26
Key1: D2 93 69 44 CC 94 E3 A7 57 B4 AF 93 7A 15 91 6B
but actualy the keys that chaged friday are :
key 00 ":E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26 key01: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD
i mean i did not have to enter key 1 that is suposed to be active 60-77-1c-7e.......... while other viewsat i have if i dont enter the key one i talked about nothing work .
Username: Candy1
can anyone tell me the new file bin for pansat2500a
Thank you!
Username: Trucker
Post Number: 39
"yanniss" the reason why your viewsat still working with the old key01, because key00 is still the active key. when the new key01 becomes active, your autoroll should kick in and change keys. hope this helped.
Username: Hawaiian_time
Hawaii
Post Number: 692
annspring, latest file for the 2500 is X-85BL_061027_283_db_api(N).bin. That bin was just available yesterday for autoroll problems.
Username: Orjane
Post Number: 7
bev keys ?plz
Username: Lakers123
Post Number: 21
i have a quick question on a pansat 3500 my channels are a lil mesed up in the echostar package there is no 417 the ppv chanels there are two of the same ones how can i get ma echostar chanels to be right if some one can help me thank you
Username: Ustaad_hc
Post Number: 92
Go to channel edit and delete all echostar package and rescan it.
Username: Zibruno
Post Number: 8
does the new bin for pansat 2500 x_85bl auoroll work for bev and dn? It seems to me that it only works for bev and yes my autoroll is on for both? Could it be there was a glitch when i downloaded it to my machine.
Username: Lklives
Post Number: 5066
bin 283 works on BOTH and autorolls great....be patient!
Username: Zibruno
Post Number: 9
I was patient but the strange thing is that i only had to change 1 key only everything else was ok. Why didn't it change that one key. Don't you find that wierd?
Username: Ustaad_hc
Post Number: 94
there is different different Keys for Bev and DN. so make sure . u have to put both keys. nagravision 2......
Username: Zibruno
Post Number: 10
I know hc i was tralking about autoroll only working for bev and not dn.
Username: Ustaad_hc
Post Number: 96
MAKE SURE IN THE PARENTAL CONTROL.........KEY EMU ....CLICK ON IT THERE IS
1.KEY CODE ON
2.DISH AUTO ON
3.BEV AUTOROLL ON
4.GLOBESAT AUTOROLL ON
MAKE SURE ALL ON
Username: Zibruno
Post Number: 11
yes i did that already trying that as we speak.
Username: Zibruno
Post Number: 12
already started 3 times over and still no picture.How long should it take?
Username: Ustaad_hc
Post Number: 98
some time Bins will not work for all.
Username: Ustaad_hc
Post Number: 99
put the new keys manually and turn off the auto roll.
Username: Lakers123
Post Number: 22
hc
how do i re scan it?
Username: Lklives
Post Number: 5070
Autoroll on Pansats and their clones works for Both Bev and DN....may take 1 hour...I said "be patient"...U should SUBSCRIBE!....U are a SPOONER, not a patient peep or tester!
