Amp turned off!!
Username: Typer__coupe94
I got a problem with my car audio amplifier.. The amp was working for
me for like 3 weeks.. Then im driving one day and the amp turns off..
The next day im driving for a while and the amp turns on.. Then like 2
hours later the amp turned off for good.. I dont know whats the problem.
I ran a little speaker cable from the remote wire on the amp to the
battery wire on the amp as a tester, and then amplifier turned on but the
subwoofers sound really messed up.. Then when i take the little speaker
wire off the remote or battery cable, amp turns off again.. I need help if any one could tell me whats the problem it would be a great help..
Thanks....
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3161
wires
Whats about the wires i need new ones?? The remote one i already replaced and still dosent work so which one is messed up??
Username: Logan__tille
AudioqueUSA
Post Number: 2069
is it in protection mode?
AudioqueUSA
Post Number: 2070
what kind of amp is it?
Fi Audio BTLUSA
Post Number: 6610
maybe your ground is loose. double check all your connections.
When i turn the car on it gose into protection for like 1 second then off and the amp still dosent turn on..
Fi Audio BTLUSA
Post Number: 6612
what kinda amp is it and what are the specs to the amp?
I checked all connections and they are all fine then i tested the battery wire and the remote the ones that go into the amp and when i put one side of the wire on the remote wire on the amp and i put the other side of the wire on the battery wire on tha amp, the amp turns on but then tha subs sound messed up then it turns off again.. Then i did it again and same thing..
its a U.S Sacoustics amp 600 Watts and i got them to 2 10in infinity subs 250w rms 1000w peak
Fi Audio BTLUSA
Post Number: 6616
how is your gain set? did you turn it all the way up? also did you check the connections to your subs? is it a clean connection to your subs?
yea the connection is ok with the subs.. But what do i do with the gain do i put it down then the amp would turn on??
AudioqueUSA
Post Number: 2074
you gain is not set corectly. what kind of head unit do you have?
Post Number: 7
i got a pioneer permire.. Im guessing its the ground cuz tha battery is makeing contact and the remote is good 2. Im thinkin is that im not getting any ground dose any body know the best place to but the ground cable at.. I tried under the seat on the seat belt bolt in the drunk by the gas tank.. If any one knows were is a good place to put ground hit me up..
AudioqueUSA
Post Number: 2085
set the gain about 1/3 of the way up
