Bronze Member Username: Jblanford
Post Number: 35 Registered: Oct-06
Posted on I'm getting 4 10 Fi ssd's and i need an amp, prolly around 2500 to 3000 at 1 ohm and i only want to spend about 400-500$...any suggestions... |
Gold Member Username: Logan__tille
AudioqueUSA
Post Number: 2101 Registered: Feb-06
Posted on orion 25OOd |
Post Number: 36 Registered: Oct-06
Posted on thats what i thought but doesnt it only do 1200 at 1 ohm ?, but this is what ive heard... |
Gold Member Username: James1115
Ct
Post Number: 7157 Registered: Dec-04
Posted on hope you have the electrical upgrades to back up that power. |
Silver Member Username: Nyyfan13
VA
Post Number: 515 Registered: Jul-06
Posted on nah it does 2500 @ 1 ohm |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 3619 Registered: Mar-04
Posted on the orion old ('05) 2500d does 2500wrms @1ohm the new D2400 only does 1200wrms @1ohm |
Post Number: 37 Registered: Oct-06
Posted on ya i get it now...thanks im gonna do the big three and optima battery under the hood and when the get the extra money i will get bigger alternator |
Ct
Post Number: 7159 Registered: Dec-04
Posted on I would do the big three and an alt then a battery. Look inot kinetic batteries not optima. |
