C*olsat help to enter keys
Username: Lionking
Post Number: 28
please can somebody please let me know which lines to change to enter new keys in co*lsat 5000
Username: Abj
Post Number: 341
lionking,
Key 0: E6 80 E6 01 DB 7D EE 4D 9B 12 EC 90 62 27 AD 26
Key 1: 60 77 1C 7E 27 D2 F4 80 50 5E 4A A2 68 03 F2 CD
Loading keys into your Co*lsat 5000.
To do this you will need the current keys. If you do not have the current keys you can use CyberDBS Nagra2 Tools to obtain them. If you are using CyberDBS Nagra2 Tools you simply download the file, extract to a folder click on the program, hit "Keys" tab, then hit "Get Keys". Now you have the current keys.
Now that you have the current keys lets get started.
1. On you Co*lsat go to a channel even if it say scrambled.
2. On the remote hit 8282 bringing up the "Key Edit" screen.
3. Tab 1 you will see Nagravision with CAS Nagravision and Ident D-N (0001)
4. Use the Channel Down on the remote to scroll down to the line beside "10"
5. You will have 8 sets of 2 digits highlighted, this is where you edit.
6. On the remote enter a number with the keypad or hit info to change each of the two digit keys.
7. Scroll down to 11, 20, and 21 to do the same with the different keys.
8. When you are done hit "Exit" on the remote and select "Yes" to save changes and exit out to watch television.
Username: Abj
Post Number: 343
lionking,
Username: Lionking
Post Number: 29
thanks justice it was of great help
Username: Woofy
Ontario Canada
Post Number: 305
You know if you load bin 135 that autoroll works and you won't have to manually enter new keys.
