The receiver started to switch off almost every time I try to use anything from the menu. Even when you are watching TV. Without reason. Last time I scanned, it took me forever because of that - just before saving the programmes it swithed off. Any suggestion why?
dear Melissa, Your reciver may have more than one satellite which cannnot read or take your programme or scanning, best thing to delete the one you r not required, then try doing the process of blind scan whatever doing, that is the reason it will take solong.
Download the factory bin 272 into your receiver and then download the latest bin 282T into your receiver. Then, do a factory reset of your receiver and then re-scan all your satellites. Then, enter the latest keys. You can find the latest files and latest keys at www.dssworld.co.nr and register there for FREE because after 5 days the download page will have some kind of password protection, members will be able access it only. So, ..... Hurry Up!
