Gold Member Username: Thomas_g
NM
Post Number: 1900 Registered: Oct-05
Posted on How good is this amp?? Does any 1 know its actual power potential?? Its supposed to put out 2000 at 1 ohm but now sure. Would u get one of these or a NINe.1?? Could i run 2 dual 1 ohm subs to a 1 ohm load on this??lol sorry i went blonde.. |
Silver Member Username: Tdawg30
Ohio
Post Number: 381 Registered: Jun-06
Posted on yes you can run those to a one ohm load, what subs are you using? You will prolly see around 1700-1800 out of that amp at 1ohm |
Gold Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 3084 Registered: Dec-05
Posted on nice amp for the budget |
NM
Post Number: 1907 Registered: Oct-05
Posted on i was thinkin 2 12" Q's wut u think?? dual 1 ohm |
Post Number: 3102 Registered: Dec-05
Posted on TJ, better get 2 Fi SSD and you can power them properly don't you think?? 900w rms for the Q is not bad, but you know they can hold way more power |
