Username: Kickerman Post Number: 38 Registered: May-06
Thursday, October 26, 2006 - 23:48 GMT i know they are not the best but i have 4 12" kicker cvrs dual 4 ohm. I have an Audiobahn 8002t amp already. i wanted to know should i take and buy another 8002t amp or should i just run two kx 1200.1's to each one and wire them down to 1 ohm. would the kx be to much power for them or should i just buy the other audiobahn amp. any help would be greatly appreciated
Username: Ctmike Ct.
Post Number: 2112 Registered: Feb-06
Friday, October 27, 2006 - 00:52 GMT the kicker would be to much for them, each one will see 600+w. if thats all you can afford then the audiobahn would be your best bet.
Username: Kickerman Post Number: 40 Registered: May-06
Friday, October 27, 2006 - 02:16 GMT well thats not all i can afford but i dont know what else to choose
Username: Tjmutlow Post Number: 3075 Registered: Sep-05
Friday, October 27, 2006 - 02:18 GMT buy another audiobahn and run at 4ohm load, it is your cheapest way
Username: Kickerman Post Number: 41 Registered: May-06
Friday, October 27, 2006 - 02:21 GMT well what would be the best way instead of the cheapest way what would be the best amp or amps to power all four properly
Username: Tjmutlow Post Number: 3076 Registered: Sep-05
Friday, October 27, 2006 - 09:27 GMT the kicker zx 1500.1 would be great for them. or even the 2500.1 you will need an amp that is 2ohm stable or .5ohm stable and produces 1500-2000w
Username: Johammbass IRL
Post Number: 452 Registered: May-06
Friday, October 27, 2006 - 09:48 GMT Hey TY MUTLOW, where are you from? You seem to be in the same time zone as me
Username: Tjmutlow Post Number: 3077 Registered: Sep-05
Friday, October 27, 2006 - 11:19 GMT virginia beach
Post Number: 456 Registered: May-06
Friday, October 27, 2006 - 13:57 GMT Oh sh:t, that's not my time zone
Username: Juliob Santo DomingoDominican Re...
Post Number: 3118 Registered: Dec-05
Friday, October 27, 2006 - 17:52 GMT the bahn is not a bad idea, but the ZX would be better, also more expensive lol!
