everytime i do a fac. flash put a new bin on flu cant get no signal ,but do ascan anyhow get 82,91,110 believe me everthing is right,runnin a viewsat in other room .different switches,cables,read of this happening elswhere any ideas??????
You need to check the settings, everytime you do a factory reset the receiver will loose all the info on the sat config......so you have to go through the menus and put the sat settings again....
