FOR ANYONE WHO HAVING TROUBLE LOADING YOUR FTA MAKE SURE U HAVE RIGHT CABLE TYPE FIRST
Want to know what cable you need to flash that shiny,new receiver ? There are two types of cables used, and both look the same on the outside, but are wired differently internally.
They are the straight DB9 RS232 female to female cable, and the Null 9 pin RS232 female to female cable. The straight DB9 cable has all pins connected the same at both ends(pin 1-1, 2-2,3-3,etc.).
The Null cable(also known as a Null-Modem) has pins 2 and 3 crossed(pin 2-3, 3-2). You can use a straight DB9 cable to program receivers requiring a Null cable, by purchasing an inexpensive Null adapter to attach to one end of the straight DB9 cable. This allows one cable to be used for any receiver.
Here is a list of the most popular receivers on the market and the cable needed to program them.
Ariza Ultra 400/500 - Null
Astrovox 2600 - Straight DB9
Blackbird/all Blackbird clones(BOB, Max 1000, Stealth II, MS1000,etc) - Null
Cool*sat 4000 Plus - Null
Cool*sat 4000 Pro - Straight DB9
Cooltec - Null
Coship (All) - Null
Digiwave 6800/7000 - Null
Digiwave Diamond - Straight DB9
Dreambox (All)-Null
Fortec lifetime - Straight DB9
Fortec Lifetime Ultra - Straight DB9
Lava 2600 - Null
Max 2500 - Null
Megasat (All) - Straight DB9
Microroyal (All) - Null
Pansat 2300a/2500a and all clones - Straight DB9
Pansat 2700 - Null
Pansat 3500 - Null
Pansat 5000HC - Null (Also can program through USB)
Pantec/Multistar Max (All) - Null
Pantec/Multistar MS (All except MS1000) - Straight DB9
Pantec MX/Ultra - Straight DB9
Rex1 - Null
Silver bullet/ST 1000/2000 - Null
Skyview 500 - Straight DB9
Spacestar DVB500 - null
Stealth 2000a- Null
Ultrastar 5000 - Null
Ariza 7XX - Null
Cool*sat 5000 Platinum - Straight DB9
Cool*sat 6000 - Straight DB9
Viewsat VS2000/Platium/Extreme - Null
Please feel free to e-mail us with any questions or concerns.
