2 10" MTX subs(400w rms) dual 4 ohms-2 12" MTX subs(400w rms) dual 4 ohms- 1 15" MTX Thunder 9500(1000w rms) dual 4 ohms...i was shopping around for a nice set up n found these nice subs, in my opinion, but couldnt find a good bridgeable 1000w rms amp to run them(1 amp per pair, 500w a peice, except for the 15" which would have its own amp) so what do u guys think would be the best amp(price range- $500-$600 a peice) Thanx
actually...5 subs(2 10s 2 12s n a 15) but even if the 10s were running on its own amp 12s on its own awp n then 15 running on its own, it still wouldnt sound good/balanced?
Sexakin69 i dont know y you want them all connect no point it sound crap stay with the 2 12" or the 15" but before u pic what your going to do buy a good name amp cuss i have buyed 1000 watt amps from germay that coundnt run 12" 500 watt sub Lol so get some advoice if u want them all on u better have a good battery and like 3 preouts on the headset cuss if u do wire al lthat **** up u'll have a dead battery fast plus what headunit u uesing ?
k well i finally chose a set up that i think will be good...2 12" Kicker solarbaric L7's with 2 kicker ZX 1000.1 and a 2 farad capacitor...also, whats the best capacitor you guys can think off?... i seen alot of cheap power acostic capacitor but i heard that they are sh*t
:D. Seeing that he was going to spend like 200 or so for two caps, mind as well get a HO alt. for a little extra and well worth the money. Also I don't usually post in here, but the subwoofer section is down .
k guys thanx alot...by the wayy...whatta bout a yellowtop just to be sure i dont kill the battery...u think i'll have to go as far as upgrading the wiring to the alt. battery. ground. etc.??
