Silver Member Username: Livin_loudNy Post Number: 357 Registered: Jan-06 | Well I tried this one in the Amp forum, and got nothing, so to here it will move... Now to the question, so how could I modify my amp to run at 1ohm and push twice the wattage, when it runs at a 2ohm factory minimum? There has to be a shop you can take it to, correct? |
Silver Member Username: BernymacRialto, CA United States Post Number: 613 Registered: Sep-04 | Pretty much yes, its been done before. |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 2307 Registered: Feb-06 | yesh theres a shop on the internet but i forgot all u have to do its install bigger mosfets, bigger caps, and if u want the ultimate change the power supply |
Silver Member Username: Livin_loudNy Post Number: 359 Registered: Jan-06 | Anybody know a site? |
Gold Member Username: Van_manBoston South, MA Post Number: 1065 Registered: Mar-06 | Google Some mods only remove the protection curcuits allowing it to run at a lower ohm. It will work for a while, but with out ^^^ caps, mofits, PS, it will cook. |
Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1356 Registered: Nov-05 | anybody got a link? i'd like to change the power/ground inputs to accept 1/0 |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1738 Registered: Jan-06 | It is cheaper to replace the amp, I have my shop set up for repairs and have been learning for the past two years as a hobby. You cannot just bipass the protection ciruit, it will eventually fail. The biggest reason being is the pathways are designed for a certain amount of power transfer overwhelm them and they begin to burn. Theoretically anything is possible but you may need to change the primary power supply winding the large torroidial transformer you see when you remove the cover, the powersupply fets, the output fets the pathways will need to be reinforced, a lot of work, lol. Polo.. |
Silver Member Username: JohammbassCork, Co.Cork Ireland Post Number: 394 Registered: May-06 | Polo is right, It's like you will have to build it all yourself, hmm, well there is a plus - it will be hand made, but in reality - it is cheaper to simply buy a more powerful amp |
Gold Member Username: Matt12490The biggity biggity BAY, California USA Post Number: 1408 Registered: May-05 | lilrob i thought you said you got this done? |
Gold Member Username: RovinTrinidad & T... Post Number: 9517 Registered: Jul-05 | polo is right it'll work but the amp's lifespan will be significantly shortened - go read it on www.bcae1.com i remember seeing wire gauge adapters u can buy like if u have 0g wire that u want 2 plug into ur amp 4g terminals it will make it fit ......... |
Gold Member Username: FrkkevinLake Worth, Texas US Post Number: 1360 Registered: Nov-05 | can't use them due to space limitations.. but ima just use some battery termial posts for side mount so i can mount my wire at a 90 degree angle to the amp |
