Username: Dan2525 Post Number: 1 Registered: Oct-06
Wednesday, October 25, 2006 - 04:50 GMT is there still a way to find the channel lock password on the memory dump screen... 3100 reciver ... i have read old posts and it appears that the location and maybe the format has changed. i have checked line 320 and 1c0 like the old instructions say but they are both 00000000 and 0000 is not the password. thanks
Username: Pannu16 Post Number: 300 Registered: May-06
Wednesday, October 25, 2006 - 04:53 GMT try 1234 or 1668
Username: Dan2525 Post Number: 2 Registered: Oct-06
Wednesday, October 25, 2006 - 05:03 GMT those don't work... is not a default password... there used to be a way to find it out from the memory dump screen. any ideas?
Username: Minn_rock Post Number: 481 Registered: Aug-06
Wednesday, October 25, 2006 - 05:35 GMT try 8282
Username: Lklives Post Number: 4946 Registered: Jan-06
Wednesday, October 25, 2006 - 14:41 GMT 3100 is a Dishnet receiver NOT a FTA receiver!...its a completely different process! dan.. look at www.kickinchicken.org
Username: Lklives Post Number: 4952 Registered: Jan-06
Wednesday, October 25, 2006 - 15:51 GMT or try this... http://forums.dsstester.c *om/vbb/showthread.php?t=31635
