Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 53 Registered: Jun-06 | can i use this amp with a 15 inch kicker dual 4 ohm solo-baric L7? http://www.crutchfield.com/S-keuddFZn4ba/cgi-bin/ProdView.asp?i=037A8000T |
Gold Member Username: CtmikeCt. Post Number: 2080 Registered: Feb-06 | yes, but you'd be underpowering it some. |
Bronze Member Username: Sk8erjimScottsmoor, Florida U.S. Post Number: 54 Registered: Jun-06 | will it be quiter if i underpower it than if i give it the perfect amount of power? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3072 Registered: Dec-05 | just get a 1000w rms amp at 2 ohms like kicker ZX 1000 |
