Enter Keys Manually for Xtreme receiver?
Username: Tariqic
Post Number: 85
How do I enter keys manually in Xtreme? Thanx
Username: Prfrmnj
Post Number: 656
Enter the main menu and select #3 for Installation, then go to #7 for Code. In the code menu you will find the options to entre keys for Nagra. Once in there use the left and right arrows to get to Dish or Bev (which ever you are entering).
Username: Tariqic
Post Number: 86
Thanx, much appreciated.
Username: Tariqic
Post Number: 87
Tried that, but unable to enter in keys. There are 32 numbers but in Xtreme there are more slots. Also, what is the Provider Id for Bev? It only has 6 characters. Thanx
Username: Lklives
Post Number: 4928
all I can say is WOW!...amazing!...I bet its posted here at least 300 places on how to input keys into an Extreme..I know of 10 places I can get in 2 minutes here..
Username: Lklives
Post Number: 4929
Odd,,,hmmmmm..it appears that someone named "t" asked this EXACT same question in a thread SUBJECT just 12 days ago and already received a detailed reply..co-incidence?...no way!
https://www.ecoustics.com/electronics/forum/home-video/277741.html
Username: Jojogun
Fairfield, CA United States
Post Number: 200
Why do you need to enter keys manually in an xtreme? I got an xtreme and my keys autoroll, on dish and bev. Just download the autoroll fix and you won't have to enter keys manually.
Username: Tariqic
Post Number: 88
Thanx Jojogun, BTW LK, if you check the username on that thread, its someone else. Also, thank you for that thread and info. Have a good one!!!
Username: Lklives
Post Number: 4930
There is GREAT info in the ARCHIVES...and use the SEARCH feature here...U can ALWAYS find your answers there..
