Username: Winterfreshpimp Chisago,
MN
America
Post Number: 420 Registered: Mar-06
Sunday, October 22, 2006 - 04:10 GMT hey im looking at a kenwood amp, one that my buddy used to have, its the excelon line, it sounded really nice in his car wondering what you guys thought of the excelon line
Username: Bernymac Rialto,
CA
United States
Post Number: 605 Registered: Sep-04
Sunday, October 22, 2006 - 04:14 GMT IMO if you listened to it and you thought it was nice. Then its good enough for you. But depending on price, which I don't know the price and exact model your talking about, we can get you better quality stuff if you wish depending on whats your budget.
MN
America
Post Number: 423 Registered: Mar-06
Sunday, October 22, 2006 - 04:56 GMT yeah just wondering if anyone had problems with the line... its like the strongest amp kenwood makes in that line
Username: Andrew571 Stillwater/Edmond,
Oklahoma
Post Number: 145 Registered: Oct-05
Sunday, October 22, 2006 - 09:31 GMT i dunno about excelon but i had a kenwood amp that crapped out after only 10 months. im never buying a kenwood product again
Username: Imalik Jackson,
New Jersey
Ocean
Post Number: 21 Registered: May-06
Sunday, October 22, 2006 - 14:55 GMT I was a big fan of all Kenwood products at one point, I still buy Kenwood HU but thats it. I hate the amps now, they just dont last.
Username: Teddy21 Ann Arbor,
MI
Post Number: 251 Registered: Feb-06
Sunday, October 22, 2006 - 15:00 GMT what amp is it and how much is it?
Username: Basshead86 Try Google
Post Number: 7488 Registered: Aug-05
Sunday, October 22, 2006 - 15:01 GMT i have heard that Excelon is the only Kenwood worth buying. alteraudiousa talks about their Excelon speakers often
Username: Van_man Boston South,
MA
Post Number: 1058 Registered: Mar-06
Sunday, October 22, 2006 - 19:07 GMT I have the X811D. Its had its problems. But after some mods, it OK. Very versitle. 533 @ 4 ohms 916 @2 ohms 1016 @1 ohm
Username: Mvplefty12 Pinellas,
FLA
America
Post Number: 138 Registered: Mar-06
Sunday, October 22, 2006 - 20:17 GMT I used to have the x621... pretty good amp. Gets warm every now n then, but it pushed my subs good.
MN
America
Post Number: 424 Registered: Mar-06
Monday, October 23, 2006 - 01:11 GMT thats the one i wanted to buy, the x811d, two of them for my arsenals... id only run the amp at 2 ohms so heat shouldnt be a prob
MA
Post Number: 1060 Registered: Mar-06
Monday, October 23, 2006 - 01:40 GMT Mine had power supply problems, but thats caused I zaped the case with the Positve. I also had some caps replaced to higher value one. Its not the worst amp, but its not the best either. I would take the X811 over the X812 too. Nad it does put out some decent power. Ive benched 920wrms unclipped out of mine at 1 ohm
Username: Motomaze Ont
Post Number: 90 Registered: Sep-06
Monday, October 23, 2006 - 03:14 GMT i have the x889 head unit and the x501 4 ch. and the x 401 mono that will handle 1/2 ohm load. ive never had a problem with these amps and they where bought in 1999
MN
America
Post Number: 426 Registered: Mar-06
Monday, October 23, 2006 - 04:30 GMT all right so i think im gonna go with 2 x811d's into 2 ohms...
MN
America
Post Number: 427 Registered: Mar-06
Monday, October 23, 2006 - 04:36 GMT less chance of frying??? cause its 1ohm stable, and at two ohms would it heat up less???
