Can i use...
Username: Sk8erjim
Scottsmoor, Florida U.S.
Post Number: 46
can i use this kenwood amp for a 15 inch kicker dual 2 ohm L7? http://cgi.ebay.com/KENWOOD-KAC-9152D-1800-WATT-MONO-AMP-CLASS-D-NEW_W0QQitemZ18 0042323339QQihZ008QQcategoryZ79828QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Alias747
MN
Post Number: 1484
Yes you can but you are going to be underpowering those L7s. If I remember correctly they are rated for 750 wrms right? Kenwood doesn't make too hot of amps so I am sure this is overrated. You need something that will give the L7s a solid 1500 wmrs @ 2 ohms.
Username: Dmm2005
Warrenton/Raleigh, North Carolina USA
Post Number: 93
That amp is about the right rms rating but for that one sub you would have to get dual 4 ohm voice coils because the ohm load that it puts out the 900 rms is at 2 ohms. Running it at one or four ohms will not put your power where you want it to be.
Username: Sk8erjim
Post Number: 49
like, what kind of amp?
Username: Sk8erjim
Post Number: 50
Username: Sk8erjim
Post Number: 51
so i will need to get a dual 4 ohm 15 inch Kicker L7 if i want to get this amp?
Username: Alias747
MN
Post Number: 1488
http://cgi.ebay.com/BRAND-NEW-06-CLARION-DPX11500-1500-WATT-MONO-AMPLIFIER_W0QQi temZ180041296755QQihZ008QQcategoryZ4950QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
About your best bet right there. Very cheap for the kind of power it puts out. Plus it is CEA rated so you know you will be getting the power it is rated for. Also is a very efficient amp.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3060
^^^^^one of the best budget amps right there...
If you got the dual 2 ohm just get a 1000w rms amp at 1 ohm
