Does it make a difference?
Username: Sk8erjim
Scottsmoor, Florida U.S.
Post Number: 55
does it make a difference if u have an amp that underpowers a subwoofer than when u have an amp that is the reccomended watts for the sub?
Username: Alias747
MN
Post Number: 1493
Well YA! If you are underpowering your sub your not going to get your full potential out of it. Plus it always is going to leave you wanting more. Which means you will want to turn up the volume more and more and you will melt your voice coil with lots of distortion.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3086
depends how underrated it is, for example, some 1000w rms subs, if you give them 900w, they might reach full excursion, but if you're undepowering with like 600w rms, you're going to notice some difference
